Deconz cannot connect to Conbee II anymore
I am running latest stable os and core in KVM on top of a clear linux installation. The Conbee II usb stick is attached to the kvm machine and that part seems ok. This set up has been working for a few months but a few days ago when I rebooted the machine the Deconz integration can see but not connect to the Conbee II.
I have verified that the stick works on other setups. And I have tried to reflash the stick but get the same result.
Here is a snippet of the supervisor addon logs:
13:42:22:150 Skip idle timer callback, too early: elapsed 622 msec
13:42:22:484 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2198288-if00 / serialno: DE2198288, ConBee II
13:42:22:495 COM check bootloader
QObject::connect: Cannot queue arguments of type 'QTextBlock'
(Make sure 'QTextBlock' is registered using qRegisterMetaType().)
QObject::connect: Cannot queue arguments of type 'QTextCursor'
(Make sure 'QTextCursor' is registered using qRegisterMetaType().)
13:42:24:498 COM timout query bootloader, assume application
13:42:25:716 Announced to internet https://phoscon.de/discover
13:42:26:075 device state timeout ignored in state 2
13:42:26:728 New websocket 172.30.32.1:57942 (state: 3)
13:42:29:080 device state timeout ignored in state 2
[13:42:30] INFO: Successfully send discovery information to Home Assistant.
13:42:32:080 device state timeout ignored in state 2
13:42:35:080 device state timeout ignored in state 2
13:42:35:588 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26660700.bin.GCF
13:42:35:589 GW firmware version: 0x00000002
13:42:38:080 device state timeout ignored in state 2
13:42:41:080 device state timeout ignored in state 2
13:42:41:081 start reconnect to network
13:42:44:080 device state timeout ignored in state 2
13:42:46:331 try to reconnect to network try=1
13:42:47:080 device state timeout ignored in state 2
13:42:50:079 device state timeout ignored in state 2
13:42:51:580 try to reconnect to network try=2
13:42:56:080 device state timeout ignored in state 2
13:42:56:580 try to reconnect to network try=3
13:43:01:080 device state timeout ignored in state 2
13:43:01:580 try to reconnect to network try=4
13:43:06:080 device state timeout (handled)
13:43:06:097 device disconnected reason: 1, index: 0
13:43:06:580 failed to reconnect to network try=5
13:43:06:581 wait reconnect 15 seconds
13:43:07:580 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:43:07:581 device state timeout ignored in state 1
13:43:07:581 wait reconnect 14 seconds
13:43:08:580 wait reconnect 13 seconds
13:43:09:580 wait reconnect 12 seconds
13:43:10:580 wait reconnect 11 seconds
13:43:11:580 failed to reconnect to network try=6
13:43:11:581 wait reconnect 10 seconds
13:43:12:580 wait reconnect 9 seconds
13:43:13:580 wait reconnect 8 seconds
13:43:14:580 wait reconnect 7 seconds
13:43:15:580 wait reconnect 6 seconds
13:43:16:580 failed to reconnect to network try=7
13:43:16:581 wait reconnect 5 seconds
13:43:17:580 wait reconnect 4 seconds
13:43:18:580 wait reconnect 3 seconds
13:43:19:580 wait reconnect 2 seconds
13:43:20:580 wait reconnect 1 seconds
13:43:20:588 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2198288-if00 / serialno: DE2198288, ConBee II
13:43:20:598 COM check bootloader
13:43:21:580 failed to reconnect to network try=8
13:43:22:605 COM timout query bootloader, assume application
13:43:24:080 device state timeout ignored in state 2
13:43:26:580 try to reconnect to network try=9
13:43:27:080 device state timeout ignored in state 2
13:43:30:080 device state timeout ignored in state 2
13:43:31:580 try to reconnect to network try=10
13:43:36:080 device state timeout ignored in state 2
13:43:36:580 reconnect network failed, try later
13:43:37:079 start reconnect to network
13:43:39:080 device state timeout ignored in state 2
13:43:42:079 device state timeout ignored in state 2
13:43:42:330 try to reconnect to network try=1
13:43:47:057 device state timeout ignored in state 2
13:43:47:580 try to reconnect to network try=2
13:43:52:080 device state timeout ignored in state 2
13:43:52:580 try to reconnect to network try=3
13:43:57:079 device state timeout ignored in state 2
13:43:57:580 try to reconnect to network try=4
13:44:02:080 device state timeout ignored in state 2
13:44:02:580 try to reconnect to network try=5
13:44:07:079 device state timeout ignored in state 2
13:44:07:580 try to reconnect to network try=6
13:44:12:080 device state timeout (handled)
13:44:12:085 device disconnected reason: 1, index: 0
13:44:12:580 failed to reconnect to network try=7
13:44:12:580 wait reconnect 15 seconds
13:44:13:580 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:44:13:580 device state timeout ignored in state 1
13:44:13:581 wait reconnect 14 seconds
13:44:14:579 wait reconnect 13 seconds
13:44:15:580 wait reconnect 12 seconds
13:44:16:580 wait reconnect 11 seconds
13:44:17:580 failed to reconnect to network try=8
13:44:17:580 wait reconnect 10 seconds
13:44:18:579 wait reconnect 9 seconds
13:44:19:580 wait reconnect 8 seconds
13:44:20:580 wait reconnect 7 seconds
13:44:21:580 wait reconnect 6 seconds
13:44:22:580 failed to reconnect to network try=9
13:44:22:581 wait reconnect 5 seconds
13:44:23:580 wait reconnect 4 seconds
13:44:24:580 wait reconnect 3 seconds
13:44:25:580 wait reconnect 2 seconds
13:44:26:580 wait reconnect 1 seconds
13:44:26:589 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2198288-if00 / serialno: DE2198288, ConBee II
13:44:26:600 COM check bootloader
