Deconz color temperature does not change light?
I am using a Hue light with a Hue dimmer and it is controlled via deconz. Previously I have just used Appdaemon to control the light (on/off/dim etc.) but I found that I could do it in deconz interface as well which seems to work a bit faster. I have on/off/dim working, but long press for toggling color temperature doesn’t work. I can see in the interface in both deconz and Home Assistant that the color temperature is changing, but is it not changing on the light phsyically. That worked fine when using Appdaemon, so it is not the light itself?
