I just started with Hassio on a Rasperry Pi in the basement.
I did connect a Conbee 2 (DECONZ) to connect to Sensors.
Actually I have (had)
4 Aqara Temperatur/Humidity/Pressure Sensors (Ground floor, 1st floor & 2nd floor)
2 Aqara Water Leak Sensors
3 Door/Window Open/Close Contacts (ground floor)
connected plus
1 Philips Hue bulb
1 Osram bulb.
All worked fine including a notification setup for 1 user. For 3 weeks…
At that time - mid of January - I tried to change the notification from single to 2 users.
Afterwards, ALL open/close sensors and a temperature sensor in ground and 1st floor have severe problems…lost connection and the open/close sensor do not even connect.
My next try will be to have some OSRAM plugs added as relay station in ZIGBEE network…but , the temperature sensor in 2nd floor (!) is working fine since the beginning…
What to do to have a general reset for the sensors in DECONZ AND HA ?
Every sensor I do re-connect seems to get the same ‘name’ like i.e. openclose_22 etc.
Regards,
Joerg
