I run my Ha in a nuc, and have atthaced a deconz conbee 2. everything is working fine.
I have a raspberry b3+ and I want to install one instance of HA for test and (or) as a backup.
Is there a way to (somehow) sent the deconz data (some aqara sensors) from the nuc instance to raspberry?
You can connect “infinite” amount of hass instances to Deconz
so If install HA to rasp it will “see” the deconz attached to my nuc?
Depending on how you’ve installed it yes
Can you elaborate please? I am going to install with official suggested way … the following
I meant it depends on how deconz is installed
