Hi I ended up using this link and all works really well.
Running on a seperate pi rather than a NUC running docker solved it for me
currently, due to a faulty SD, I went different route: create a new VM in proxmox, with simple debian desktop (for being able to see the mesh), with only deCONZ software, and of course the COnbee stick attached to USB only for that VM
how do you get the api start the 60 sec then move it to the pie to finish
You need to login into your Deconz http://192.168.xx.xx:80 from a web browser and the select
Then
Then
Then
Then go to your Homeassistant web page and goto configuration and select intergrations hit the big orange + button select deConz.
and as long as you are on the same network select it from the list.
Hope this helps.
Hope this helps.
just to be clear leave the deconz plugged into the pi right the whole time
Yes it does help.
alright i tried several times and still cant get the api
i took screen shoots of the whole process if you need to see them
Are you on the same network ?
No I was not but I got it finally got it thank you for helping me so it should just be add devices now right
I am glad you got there.
