I see here in the code that only two config options (Delay and Duration) are available through GUI for Presence sensors in the deCONZ plugin (if I understand correctly)
The mmWave sensors often have other very useful config options such as ‘sensitivity’ and ‘triggerdistance’.
Is this something that has been discussed before to be added? How can I go about adding it? And also, is there a way to generalize this, in order to avoid adding code for every single configuration option?
Years since I’ve used Deconz, so I don’t have a solution for what you’re asking spesifically, but have you considered Zigbee2MQTT? It supports what you’re asking for most likely.
