I have a handfull sensors attached to a deconz stick.
After an attempt to update to 0.104.1, and a roll-back to 0.103.6 I’ve lost all connections to them.
I can see all the sensors, but they just don’t change state when I manipulates the sensors, this is when I view it from inside deconz…
If I connect to deconz via VNC I don’t see connections between all the sensors and the stick.
Hmm, the only way so far is to remove the sensors and add them back in. This worries me quite a bit, as this will be impossible to do when I move everything over…
So this has nothing to do with HA…
Not directly, but it happened when HA was rebooted.
