@Robban
There are a lot of “new things” on my logs that weren’t there before.
DEBUG (MainThread) [pydeconz.utils] Sending {'auth': None, 'data': b'{"devicetype": "pydeconz"}'} to http://192.168.1.71:8080/api
2018-05-17 11:58:45 DEBUG (MainThread) [pydeconz.utils] HTTP request response: [{'success': {'username': '39D3AA1F64'}}]
2018-05-17 11:58:45 INFO (MainThread) [pydeconz.utils] API key: 39D3AA1F64
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.setup] Setting up deconz
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.setup] Setup of domain deconz took 0.0 seconds.
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.utils] Sending {} to http://192.168.1.71:8080/api/39D3AA1F64
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.utils] HTTP request response: {'config': {'UTC': '2018-05-17T10:58:47', 'apiversion': '1.0.9', 'backup': {'errorcode': 0, 'status': 'idle'}, 'bridgeid': '0000000000000000', 'datastoreversion': '60', 'dhcp': True, 'factorynew': False, 'fwversion': '0x00000000', 'gateway': '192.168.1.1', 'internetservices': {'remoteaccess': 'disconnected'}, 'ipaddress': '192.168.1.71', 'linkbutton': True, 'localtime': '2018-05-17T11:58:47', 'mac': 'b8:27:eb:b2:ee:3d', 'modelid': 'deCONZ', 'name': 'zigbee-gw', 'netmask': '255.255.255.0', 'networkopenduration': 60, 'panid': 0, 'portalconnection': 'disconnected', 'portalservices': False, 'portalstate': {'communication': 'disconnected', 'incoming': False, 'outgoing': False, 'signedon': False}, 'proxyaddress': 'none', 'proxyport': 0, 'replacesbridgeid': None, 'rfconnected': False, 'starterkitid': '', 'swupdate': {'checkforupdate': False, 'devicetypes': {'bridge': False, 'lights': [], 'sensors': []}, 'notify': False, 'text': '', 'updatestate': 0, 'url': ''}, 'swupdate2': {'autoinstall': {'on': False, 'updatetime': ''}, 'bridge': {'lastinstall': '', 'state': 'allreadytoinstall'}, 'checkforupdate': False, 'install': False, 'lastchange': '', 'lastinstall': '', 'state': 'allreadytoinstall'}, 'swversion': '2.5.25', 'timeformat': '24h', 'timezone': 'Etc/GMT-1', 'uuid': '77dd8957-f013-4de8-9507-3efaa9a7b75c', 'websocketnotifyall': True, 'websocketport': 8443, 'whitelist': {'39D3AA1F64': {'create date': '2018-05-17T10:58:45', 'last use date': '2018-05-17T10:58:47', 'name': 'pydeconz'}, '3F430DA686': {'create date': '2018-05-17T10:41:09', 'last use date': '2018-05-17T10:41:09', 'name': 'Phoscon#B1490x953'}, '6A660B97E0': {'create date': '2018-05-17T10:54:03', 'last use date': '2018-05-17T10:58:44', 'name': 'Phoscon#B1490x953'}}, 'zigbeechannel': 0}, 'groups': {'1': {'action': {'bri': 128, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 128, 'scene': None, 'xy': [0, 0]}, 'class': 'Other', 'devicemembership': [], 'etag': '0e510da9cba3786ad656f0d7c5377eaa', 'hidden': False, 'id': '1', 'lights': [], 'lightsequence': [], 'multideviceids': [], 'name': 'Bedroom', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}}, 'lights': {}, 'resourcelinks': {}, 'rules': {}, 'schedules': {}, 'sensors': {'1': {'config': {'configured': False, 'on': True, 'sunriseoffset': 30, 'sunsetoffset': -30}, 'etag': None, 'manufacturername': 'Philips', 'modelid': 'PHDL00', 'name': 'Daylight', 'state': {'daylight': None, 'lastupdated': 'none', 'status': None}, 'swversion': '1.0', 'type': 'Daylight', 'uniqueid': '00:00:00:00:00:00:00:00-01'}}}
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.config] Deconz config loaded {'_apiversion': '1.0.9', '_bridgeid': '0000000000000000', '_linkbutton': True, '_modelid': 'deCONZ', '_name': 'zigbee-gw', '_networkopenduration': 60, '_panid': 0, '_swversion': '2.5.25', '_uuid': '77dd8957-f013-4de8-9507-3efaa9a7b75c', '_websocketport': 8443, '_zigbeechannel': 0}
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.deconzdevice] Bedroom created as {'_any_on': False, '_bri': 128, '_class': 'Other', '_colormode': 'hs', '_ct': 0, '_devicemembership': [], '_effect': 'none', '_hidden': False, '_hue': 0, '_id': '1', '_lights': [], '_lightsequence': [], '_multideviceids': [], '_on': False, '_reachable': True, '_sat': 128, '_scenes': {}, '_x': 0, '_y': 0, '_async_set_state_callback': <bound method DeconzSession.async_put_state of <pydeconz.DeconzSession object at 0x70236c90>>, '_deconz_id': '/groups/1', '_etag': '0e510da9cba3786ad656f0d7c5377eaa', '_manufacturername': None, '_modelid': None, '_name': 'Bedroom', '_swversion': None, '_type': 'LightGroup', '_uniqueid': None, '_async_callback': []}
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.deconzdevice] Daylight created as {'_daylight': None, '_status': None, '_battery': None, '_ep': None, '_on': True, '_reachable': None, '_sensor_class': None, '_sensor_icon': None, '_sensor_unit': None, '_deconz_id': '/sensors/1', '_etag': None, '_manufacturername': 'Philips', '_modelid': 'PHDL00', '_name': 'Daylight', '_swversion': '1.0', '_type': 'Daylight', '_uniqueid': '00:00:00:00:00:00:00:00-01', '_async_callback': []}
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=deconz, service=configure>
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=deconz>
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.loader] Loaded sensor.deconz from homeassistant.components.sensor.deconz
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds.
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=binary_sensor>
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.setup] Setting up scene
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=scene, service=turn_on>
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.0 seconds.
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=scene>
2018-05-17 11:58:47 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1882378512: Sending {'id': 377, 'type': 'event', 'event': {'event_type': 'service_registered', 'data': {'domain': 'deconz', 'service': 'configure'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2018, 5, 17, 10, 58, 47, 144470, tzinfo=<UTC>)}}
2018-05-17 11:58:47 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1882378512: Sending {'id': 377, 'type': 'event', 'event': {'event_type': 'component_loaded', 'data': {'component': 'deconz'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2018, 5, 17, 10, 58, 47, 147027, tzinfo=<UTC>)}}
2018-05-17 11:58:47 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1886693872: Sending {'id': 4, 'type': 'event', 'event': {'event_type': 'service_registered', 'data': {'domain': 'deconz', 'service': 'configure'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2018, 5, 17, 10, 58, 47, 144470, tzinfo=<UTC>)}}
2018-05-17 11:58:47 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1886693872: Sending {'id': 3, 'type': 'event', 'event': {'event_type': 'component_loaded', 'data': {'component': 'deconz'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2018, 5, 17, 10, 58, 47, 147027, tzinfo=<UTC>)}}
2018-05-17 11:58:47 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1854744560: Sending {'id': 5, 'type': 'event', 'event': {'event_type': 'service_registered', 'data': {'domain': 'deconz', 'service': 'configure'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2018, 5, 17, 10, 58, 47, 144470, tzinfo=<UTC>)}}
2018-05-17 11:58:47 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1854744560: Sending {'id': 4, 'type': 'event', 'event': {'event_type': 'component_loaded', 'data': {'component': 'deconz'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2018, 5, 17, 10, 58, 47, 147027, tzinfo=<UTC>)}}
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=dismiss, service_data=notification_id=config_entry_discovery, service_call_id=1967968944-16>
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.websocket] Websocket handshake: GET / HTTP/1.1
Host: 192.168.1.71:8443
User-Agent: Python/3.5 websockets/3.4
Upgrade: Websocket
Connection: Upgrade
Sec-WebSocket-Key: I5vqPpJsxqjJ8yZlQoB2Hg==
Sec-WebSocket-Version: 13
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor.deconz from homeassistant.components.binary_sensor.deconz
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.loader] Loaded scene.deconz from homeassistant.components.scene.deconz
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.config_entry_discovery, old_state=<state persistent_notification.config_entry_discovery=notifying; title=New devices discovered, message=We have discovered new devices on your network. [Check it out](/config/integrations) @ 2018-05-17T11:56:44.478079+01:00>, new_state=None>
2018-05-17 11:58:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1967968944-16>
2018-05-17 11:58:47 DEBUG (MainThread) [pydeconz.websocket] Websocket handshake: HTTP/1.1 101 Switching Protocols
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Accept: C+HNwSGfAE4DHO3oJxIslIkae7Y=
Server: deconz
Access-Control-Allow-Credentials: false
Access-Control-Allow-Methods: GET
Access-Control-Allow-Headers: content-type
Access-Control-Allow-Origin: *
Date: Thu, 17 May 2018 10:58:47 GMT
