Deconz+hassio+ Xiaomi aqara WXKG11LM
Hi everyone, I’ve posted request for help in hassio channel and wondered if it’s useful to request help in here as well!
I have Xiaomi aqara switch WXKG11LM.
My setup is hassio+deconz addon with conbee2
It pairs successful as switch.
However, I’m not able to get buttonevent state when I press the button.
Looking at the log file on the app i see this
23:38:34:936 Device TTL 4379 s flags: 0x7
23:38:45:110 no button handler for: lumi.sensor_switch.aq2 ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 005
23:38:45:110 ZCL attribute report 0x00158D00023303F2 for cluster 0x0000, ep 0x01
23:38:45:110 0x00158D00023303F2 skip Xiaomi attribute 0x0000
23:38:45:110 0x00158D00023303F2 extract Xiaomi special attribute 0xFF01
23:38:45:110 01 battery 2975 (0x0B9F)
23:38:45:110 03 temperature 27 °C
23:38:45:110 04 unknown 13224 (0x33A8)
23:38:45:110 05 RSSI dB (?) 123 (0x007B)
23:38:45:110 06 LQI (?) 0 (0x0000000000)
23:38:45:110 0a unknown 0 (0x0000)
Deconz_event doesn’t pick any event from the button.
On node red debug, i get this
{“config”:{“battery”:100,“on”:true,“reachable”:true,“temperature”:2500},“e”:“changed”,“id”:“3”,“r”:“sensors”,“t”:“event”,“uniqueid”:“00:15:8d:00:02:33:03:f2-01-0006”}
As you can see, i don’t have a button event!
I hope you could help me.
Many thanks
For some reason I see the message below when I press the button and I suspect that this is the cause of the problem.
I don’t know how to solve it
Hi DrNerdy,
Did you ever find a solution to this? I’m having a similar issue.
Thanks.
No I’m sorry, I moved away from the button to tradfri 5 button device and I never looked back
Anyone ever figure this out. Looking for some buttons and thought I’d try this one. I’ve added it to ZHA (this is my first ever Zigbee device), and all I can see is the battery state.
Hello, it’s the same for me. Did you find the solution ?
Not yet. I’m probably going to abandon it and send it back to amazon.
In fact, I found the solution :
You have to listen the deconz events. Try it it’s work for me :+1:
