I’m using deconz to control my lights via home assistant. I can change the color to any color but the bulb color on the overview stays at a different color. With the hue hub the color was the same. Is there a solution for this?
Daranto
Daranto
What bulb are you having issues with? Is it a bulb or is it a group that doesn’t work properly?
If you can enable debug for the component and paste what data you send and what data you receive from deconz we can get to the bottom of this.
