DeCONZ Hue Dimmer Switch app with smooth dimming functionality
there is an update for appdaemon, i’ll do it and restart homeassistant.
I just checked how HA is receiving the deconz_event and noticed that the name of the switch (dimmer_switch) was wrong.
I updated it but with no success.
Listening form deconz_event:
New config in apps folder:
Oke this looks good, can you please show the log again after you added the yaml config for the dimmer switch?
here is the log again:
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: AppDaemon 4
 Python Apps and Dashboard using AppDaemon 4.x for Home Assistant
 Add-on version: 0.2.5
 You are running the latest version of this add-on.
 System: Raspbian GNU/Linux 10 (buster)  (armv7 / raspberrypi4)
 Home Assistant Core: 0.108.9
 Home Assistant Supervisor: 219
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] appdaemon.sh: executing...
[cont-init.d] appdaemon.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[11:52:14] INFO: Starting AppDaemon...
2020-04-26 11:52:15.818200 INFO AppDaemon: AppDaemon Version 4.0.3 starting
2020-04-26 11:52:15.818636 INFO AppDaemon: Python version is 3.8.2
2020-04-26 11:52:15.819003 INFO AppDaemon: Configuration read from: /config/appdaemon/appdaemon.yaml
2020-04-26 11:52:15.819345 INFO AppDaemon: Added log: AppDaemon
2020-04-26 11:52:15.819746 INFO AppDaemon: Added log: Error
2020-04-26 11:52:15.820089 INFO AppDaemon: Added log: Access
2020-04-26 11:52:15.820398 INFO AppDaemon: Added log: Diag
2020-04-26 11:52:15.869856 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2020-04-26 11:52:15.929713 INFO HASS: HASS Plugin Initializing
2020-04-26 11:52:15.930515 INFO HASS: HASS Plugin initialization complete
2020-04-26 11:52:15.931805 INFO AppDaemon: Initializing HTTP
2020-04-26 11:52:15.932841 INFO AppDaemon: Using 'ws' for event stream
2020-04-26 11:52:15.964704 INFO AppDaemon: Starting API
2020-04-26 11:52:15.975094 INFO AppDaemon: Starting Admin Interface
2020-04-26 11:52:15.976034 INFO AppDaemon: Starting Dashboards
2020-04-26 11:52:15.999544 INFO HASS: Connected to Home Assistant 0.108.9
2020-04-26 11:52:16.036978 INFO AppDaemon: App 'dimmer_all_lifx' added
2020-04-26 11:52:16.039080 INFO AppDaemon: Found 1 total apps
2020-04-26 11:52:16.040269 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2020-04-26 11:52:16.042267 INFO AppDaemon: Running on port 5050
2020-04-26 11:52:16.095617 INFO HASS: Evaluating startup conditions
2020-04-26 11:52:16.135956 INFO AppDaemon: Got initial state from namespace default
2020-04-26 11:52:18.059062 INFO AppDaemon: Scheduler running in realtime
2020-04-26 11:52:18.071438 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2020-04-26 11:52:18.073628 INFO AppDaemon: Adding /config/appdaemon/apps/Hue_Dimmer_Deconz to module import path
2020-04-26 11:52:18.084024 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/Hue_Dimmer_Deconz/hue_dimmer_switch_deconz.py - ignoring
2020-04-26 11:52:18.089641 INFO AppDaemon: App initialization complete
If I’m right it is correct, that the “dimmer_switch” entity is not showing up here, due to the event handling of HA?
The event id seems to be correct.
I just saw that the module name in the dimmer config is incorrect. It should be like this:
dimmer_all_lifx:
  module: hue_dimmer_switch_deconz
  class: HueDimmerSwitch
  entities:
    switch: dimmer_switch
    light: light.all_lifx
Just for your information, the smooth dimming works only with lights integrated with Deconz, the smooth dimming will not work for your Lifx bulbs, the rest will work like turn on/off, calling service etc
unzz, thx.
I would’ve probably never found it.
sad, that i cant do dimming for the lifx bulbs, that was actually my main intension.
https://github.com/Burningstone91/Hue_Dimmer_Deconz
FYI: In your advanced example config the “deconz” is missing too for the module.
Take a look at ControllerX, it’s also an AppDaemon app, but more sophisticated than mine. I don’t know how smooth the dimming is there, you need to check yourself.
Yeah, I just saw that after I corrected your code, thanks for the info.
The thing is, I probably won’t continue with this app (I’ll continue to use it in my system however), because it only supports Deconz and from the feedback I read, people are quite happy qith Cobtroller X, that I mentioned above.
I just tried it and it works quite well, the dimming is not as smooth as i was hoping for but still great and more than enough for daily use. Thx for the tipp.
Just a question i probably already know the answer to; the Hue Tab (zigbee green power) won’t be able to do this, right? You need a battery powered switch for this?
Do you use deconz? What kind of lights do you use and are they connected through deconz as well?
