Deconz - Hue switch dimmer homeKit - beginner
Hello, how are you?
I’m new here in the forum and have been reading through the forum for two days now. There are already many threads on this topic, but unfortunately I didn’t find a suitable answer or I didn’t understand it (I’m not a programmer - learning by doing is my way).
Some information about my situation:
I started with openhab and ended up at HA via Homebridge. Up to now everything runs as I wanted it to and particularly much more fluently in comparison to the other two systems.
I was able to set up Homematic, Deconz and HomeKit successfully. With the other two systems I could find the hue dimmer switch in the HomeKit app and program the automation there. I would like to do the same with this system (HA).
Can someone please help me and explain step by step what I have to do to find the hue dimmer switch in my HomeKit app?
Many thanks in advance for your help.
If there is a manual, it is of course enough for me if you could link it. Thanks a lot!
Lukas
Hi! Did you ever find and answer to this? Facing the same problem :slight_smile:
