This Blueprint can be used to control one or more lights with the IKEA SYMFONISK remote connected with deConz.
Functions:
- One click: Toggle lights
- Two clicks: Perform assigned action
- Three clicks: Perform assigned action
- Turn clockwise: Increase brightness
- Turn counter clockwise: Decrease brightness
blueprint:
name: Deconz - IKEA SYMFONISK for lights
description: 'Control lights with an IKEA SYMFONISK from the Deconz integration.
Pushing the button once, toggles the lights on/off to the last set
brightness (unless the force brightness is toggled on in the blueprint).
Rotating left/right will change the brightness.
The button can be pressed double or triple, these actions can be assigned
freely. This allows you to assign, e.g., a scene or anything else.
Thanks to @Frenck. I modified his ZHA version to make it useful for Deconz.
domain: automation
input:
remote:
description: IKEA SYMFONISK to use
selector:
device:
integration: deconz
manufacturer: IKEA of Sweden
model: SYMFONISK Sound Controller
light:
description: The light(s) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description: 'Force the brightness to the set level below, when the "on" button
on the remote is pushed and lights turn on.
default: false
selector:
boolean: {}
brightness:
description: Brightness of the light(s) when turning on
default: 50
selector:
number:
min: 0.0
max: 100.0
mode: slider
step: 1.0
unit_of_measurement: '%'
double_press:
description: Action to run on double press
default: []
selector:
action: {}
triple_press:
description: Action to run on triple press
default: []
selector:
action: {}
source_url: https://raw.githubusercontent.com/Sholofly/home-assistant-config/master/blueprints/automation/deconz_ikea_symfonisk_lights.yaml
mode: single
max_exceeded: silent
variables:
force_brightness: !input 'force_brightness'
- platform: event
event_type: deconz_event
event_data:
device_id: !input 'remote'
- variables:
event: '{{ trigger.event.data.event }}'
- choose:
- conditions:
- '{{ event == 1002 }}'
sequence:
- choose:
- conditions: '{{ force_brightness }}'
sequence:
- service: light.toggle
target: !input 'light'
transition: 1
brightness_pct: !input 'brightness'
default:
transition: 1
- delay:
milliseconds: 100
- conditions:
- '{{ event == 2001 }}' #start turning clockwise
sequence:
- service: light.turn_on
brightness_step_pct: 5
- conditions:
- '{{ event == 3001 }}' #start turning counter clockwise
sequence:
brightness_step_pct: -5
- conditions:
- '{{ event == 1004 }}'
sequence: !input 'double_press'
- conditions:
- '{{ event == 1005 }}'
sequence: !input 'triple_press'
