Sharing my blueprint to select the previous/next/first/last value of an input_select. This is used by some people to cycle through a set of scenes.
Functions:
- Long Press On: Select first
- Short Press On: Select previous
- Long Press Off: Select last
- Short Press Off: Select next
blueprint:
name: deCONZ - IKEA Tradfri on/off scene switch via input_select
description: '"Set Home Assistant scenes with IKEA Tradfri on/off switch
Select the Tradfri remote and your input_select.
You can select next or previous value of your input_select doing a short press
on the remote. Pressing long will select the first or last value."
domain: automation
input:
remote:
description: The remote that will control the selector
selector:
device:
integration: deconz
manufacturer: IKEA of Sweden
model: TRADFRI on/off switch
input_select:
name: Input Select Field
description: The input_select that will be changed
selector:
entity:
domain: input_select
source_url: https://community.home-assistant.io/t/deconz-ikea-tradfri-on-off-button-to-control-input-select/348984
mode: restart
- platform: event
event_type: deconz_event
event_data:
device_id: !input 'remote'
- variables:
event: '{{ trigger.event.data.event }}'
- choose:
- conditions:
- '{{ event == 1002 }}'
sequence:
- service: input_select.select_previous
target: !input 'input_select'
cycle: false
- conditions:
- '{{ event == 2002 }}'
sequence:
- service: input_select.select_next
cycle: false
- conditions:
- '{{ event == 1001 }}'
sequence:
- service: input_select.select_first
- conditions:
- '{{ event == 2001 }}'
sequence:
- service: input_select.select_last
