Here I’m sharing a modified version of deCONZ Ikea on/off switch with direct support for Adaptive lighting add-on.
To import the blueprint click the button below:
or take it from this link:
There were a few issues I had while using the dimmer switch together with adaptive lighting, hence this blueprint was born.
It has 3 inputs as seen on the screenshot
You need to select the dimmer switch, light group (I use room light group directly from Hue) and the adaptive lighting switch associated with the same light above.
Turn off, on and dimming is supported.
The difference between the other blueprints is that every time you turn the light on it will use the current value of the adaptive lighting switch so your light will always turn on with the correct and current light values. For example, at night, there will be no jump from high brightness to low brightness.
