deCONZ lights blueprint for the IKEA Trådfri on/off switch, including dimming functionality (button hold). Based on poolcactus ZHA blueprint for this switch.
Get started
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: deCONZ - IKEA Tradfri on/off switch
description: |
"Control your deCONZ light(s) with IKEA Tradfri on/off switch
Select the Tradfri remote and your lights.
You can turn the lights On / Off, or hold the buttons to dim the lights"
domain: automation
input:
remote:
description: The remote that will control the lights
selector:
device:
integration: deconz
manufacturer: 'IKEA of Sweden'
model: 'TRADFRI on/off switch'
light:
description: The lights that will be controlled
selector:
entity:
domain: light
mode: restart
- platform: event
event_type: deconz_event
event_data:
device_id: !input 'remote'
- variables:
event: "{{ trigger.event.data.event }}"
- choose:
- conditions:
- "{{ event == 1002 }}"
sequence:
- service: light.turn_on
target: !input 'light'
transition: 1
- conditions:
- "{{ event == 2002 }}"
sequence:
- service: light.turn_off
transition: 1
- conditions:
- "{{ event == 1001 }}"
sequence:
repeat:
while:
- condition: template
value_template: "{{ repeat.index < 10 }}"
sequence:
transition: 1
brightness_step_pct: 10
- delay: 1
- conditions:
- "{{ event == 2001 }}"
sequence:
repeat:
while:
sequence:
transition: 1
brightness_step_pct: -10
- delay: 1
- conditions:
- "{{ event == 1003 }}"
sequence:
- conditions:
- "{{ event == 2003 }}"
sequence:
