deCONZ - IKEA TRADFRI open/close including press and hold
I wanted to be able to control my FYRTUR shades in a similar fashion to the Ikea default, should also work for KADRILJ. I took @psychozz’s “deCONZ - IKEA Trådfri on/off switch (incl dimmer)” and adjusted the variables to suit the open/close switch and stripped out the brightness adjustment stuff.
blueprint:
  name: deCONZ - IKEA Tradfri open/close switch
  description: |
    "Control Furtur roller blind with IKEA Tradfri open/close switch
    Select the Tradfri remote and your blinds.
    You can open or close the blinds all the way with a single click, hold the button down to adjust them, or hit the opposing button while in motion to stop them."
  domain: automation
  input:
    remote:
      description: The remote that will control the shades
      selector:
        device:
          integration: deconz
          manufacturer: 'IKEA of Sweden'
          model: 'TRADFRI open/close remote'
    cover:
      description: The cover that will be controlled
      selector:
          entity:
            domain: cover
mode: restart
- platform: event
  event_type: deconz_event
  event_data:
    device_id: !input 'remote'
- variables:
    event: "{{ trigger.event.data.event }}"
- choose:
  - conditions:
    - "{{ event == 1002 }}"
    sequence:
    - service: cover.open_cover
      target: !input 'cover'
  - conditions:
    - "{{ event == 2002 }}"
    sequence:
    - service: cover.close_cover
  - conditions:
    - "{{ event == 1003 }}"
    sequence:
    - service: cover.stop_cover
  - conditions:
    - "{{ event == 2003 }}"
    sequence:
Do you know what to change to make this run with Z2M?
Sorry, I do not as I am not using Z2M.
how do you tell the blind what is 100% closed.
I got all the blind and remote added to DeConZ and can be seen in HA, but is there a setting in the VNC on Deconz I need to tell it what closed 100% is?
Hmm, I didn’t have to do anything special around this, HA knows nonetheless:
I use Slider Button Card to control them in Lovelace:
and it automatically knew the %.
Just want to say a BIG THANK YOU!
Integrating all my cover blinds to deConz and HA thanks to this Blueprint!
I have used this blueprint without any prioblems, but recently the blind only opens/closeds a few centimeters at a time. Then stops. Anyone know what might be wrong? It works if I create an automation manually for open/close.
I had the same question and after reading one of the 6 manuals (!!) there is well hidden the solution. :wink:
You ‘tell’ the cover itself by manual steering the cover to the wanted 100% closing followed by double press the lowest button on the cover itself. By that the cover is ‘programmed’. This position is used in displaying the relative position of the cover.
I’m not sure this is related to the blueprint, I have this same problem occasionally.
