Good morning,
I am new in this community (as a member) but I have been searching and reading through it for quite a long time now.
I come to you with an issue I can’t find an explanation for.
In my signature, you have some description of the system I run with.
My issue is the following : deconz (with phoscon Web UI) can’t detect new devices.
During my troubleshooting and to overcome this, I tested with the PC (Windows 7)
I plugged the key in my PC and ran desconz-phoscon, and it detected properley the devices (light and sensors . I configured them as I wished, no limitation.
Then I saved the configuration (shift+click on the config button).
And back to HA.
I plugged the key back into the Pi4, started deconz, and bang, I see properly the previously detected devices.
But, now, I would like to be able to add devices with unpluging -repluging the conbee II each time.
but I can’t manage.
I am pretty sure it has something to do with my docker Home-assistant installation, but I can’t find a solution.
In particular, I saw many posts about adding/changing things in the docker-compose.yml, but I can’t find such a full anywhere on the raspbian of my Pi.
So indeed, I have two questions :
-each time my Pi restart, the connection of the conbee is re-routed : it changes back and forth between ttyACM0 and ttyACM1. I have tried to follow this info to make this persistent, but I am then stuck at the docker-compose.yml step.
- what has to be done to allow the phoscon/deconz integration to detect new devices? Where is this docker compose file?
PS : I had initially installed HA on raspbian following the info posted here.
thanks a lot for your help…
Vincent
HA Core 0.118.5
installed on Raspberry PI 4, SSD. Raspian and Docker.
deConz 6.5.0
RFlink (Arduino) and Conbee II (w/ extension cord) firmware 26660700
