Sorry I don’t get it, where shall I look for IP adress?
My HASSIO 0.88 is on a NUC-Ubuntu (docker install) on LAN 192.168.1.xx
My Conbee stick is on a pi3 that runs also deCONZ software on same LAN 192.168.1.yy
I’m experiencing the same issue although both hass.io and deconz is on the same physical machine running in docker containers, hence the weird IP’s…
Each reboot i get these errors:
INFO (MainThread) [homeassistant.setup] Setting up deconz
INFO (MainThread) [homeassistant.setup] Setup of domain deconz took 0.0 seconds.
DEBUG (MainThread) [pydeconz.utils] Sending {} to http://172.30.33.1:80/api/XXXXXXXX
------ Later in the log
ERROR (MainThread) [pydeconz.utils] Timeout getting deCONZ data from http://172.30.33.1:80/api/XXXXXXXX.
ERROR (MainThread) [pydeconz] Couldn’t load data from deCONZ
WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 5 seconds.
ERROR (MainThread) [homeassistant.components.deconz] Config entry failed since one deCONZ instance already exists
If i remove deconz from the integration page and add it right after all entities comes back and it all works, until next restart, then i need to remove deconz and add it again.
I have tried to remove deconz, reboot, reboot, and then adding it again, same outcome though.
Ok, seems I have also deconz issues now… I still see the integrations… My Osram smart plugs are working
But my Ikea motion sensors and my Ikea remote switches are not working anymore
In my case after a reboot the sensors were working again, no idea what was wrong… I saw them them though as binary sensors, but the movement detection was not working… But it is now
