Hey, I got a Conbee stick and I installed it in my Qnap NAS via the Deconz docker image following this guide: https://promincproductions.com/blog/add-zigbee-to-home-assistant-with-conbee-ii-and-deconz-on-qnap-ts-251/
These are the Docker vars:
My HA is installed in a VM on the same NAS using HASS OS
The Deconz installation went well and I added a Zigbee accessory correcty. But when I try to add the Deconz integration to HA, this dialog appears:
If I select the one that HA discovered, it throws this error
So I follow the manual route, and I set the NAS IP where I installed it, 192.168.1.13, with the port I set when I installed the container. Now everything seems to work, HA gets the devices I added to the stick, but it doesn’t get updates of the devices states. I think it’s about the websocket, right?
But I don’t understand why the container gets a different IP address
The URL where I’m accessing is http://192.168.1.13:9090/pwa
I’ve tried to add to the yaml file a “websocket_port” entry but I think it’s ignoring it
