I feel that deCONZ 3.7 is stopped and it is necessary to restart. Does anyone have the same problem. this had happened after the last upgrade of HA 0.101.3
I am running Hassio with Version 0.101.3 and deconz and it’s running really smooth. Did you check the logs?
HI, this is the loog now:
Log
11:02:00:487 Device TTL 1360 s flags: 0x7
11:03:00:440 Current channel 20
11:03:00:473 Device TTL 1300 s flags: 0x7
11:03:02:280 Announced to internet
11:03:02:281 discovery server date: Mon, 18 Nov 2019 09:03:02 GMT
11:03:02:281 local time seems to be ok
11:03:06:429 dev /dev/ttyAMA0
11:03:06:429 GW firmware version: 0x26330500
11:03:06:429 GW firmware version is up to date: 0x26330500
11:04:00:439 Current channel 20
11:04:00:471 Device TTL 1240 s flags: 0x7
11:05:00:439 Current channel 20
11:05:00:472 Device TTL 1180 s flags: 0x7
11:05:00:616 no button map for: lumi.weather ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 001
11:05:00:616 ZCL attribute report 0x00158D000233066F for cluster 0x0000, ep 0x01
11:05:00:617 0x00158D000233066F extract Xiaomi special attribute 0xFF01
11:05:00:617 01 battery 3025 (0x0BD1)
11:05:00:617 04 unknown 17320 (0x43A8)
11:05:00:617 05 RSSI dB (?) 7 (0x0007)
11:05:00:617 06 LQI (?) 4294967296 (0x0100000000)
11:05:00:617 64 temperature 2544
11:05:00:617 65 humidity 4133
11:05:00:617 66 pressure 1000
11:05:00:617 0a unknown 45632 (0xB240)
11:06:00:454 Current channel 20
11:06:00:487 Device TTL 1120 s flags: 0x7
11:06:58:832 Websocket disconnected 192.168.1.27:50752 (state: 0)
11:07:00:453 Current channel 20
11:07:00:484 Device TTL 1060 s flags: 0x7
11:07:06:431 dev /dev/ttyAMA0
11:07:06:432 GW firmware version: 0x26330500
11:07:06:432 GW firmware version is up to date: 0x26330500
11:07:28:192 New websocket 192.168.1.27:51623 (state: 3)
11:07:31:828 no button map for: lumi.weather ep: 0x01 cl: 0x0402 cmd: 0x0A pl[0]: 000
11:07:31:828 ZCL attribute report 0x00158D000233066F for cluster 0x0402, ep 0x01
11:07:31:861 no button map for: lumi.weather ep: 0x01 cl: 0x0405 cmd: 0x0A pl[0]: 000
11:07:31:861 ZCL attribute report 0x00158D000233066F for cluster 0x0405, ep 0x01
11:07:31:892 no button map for: lumi.weather ep: 0x01 cl: 0x0403 cmd: 0x0A pl[0]: 000
11:07:31:892 ZCL attribute report 0x00158D000233066F for cluster 0x0403, ep 0x01
11:08:00:450 Current channel 20
11:08:00:481 Device TTL 1000 s flags: 0x7
11:09:00:450 Current channel 20
11:09:00:483 Device TTL 940 s flags: 0x7
11:10:00:447 Current channel 20
11:10:00:478 Device TTL 880 s flags: 0x7
11:10:06:258 ZCL attribute report 0x000D6FFFFEE47B99 for cluster 0x0000, ep 0x01
11:11:00:444 Current channel 20
11:11:00:476 Device TTL 820 s flags: 0x7
11:11:06:419 dev /dev/ttyAMA0
11:11:06:419 GW firmware version: 0x26330500
11:11:06:419 GW firmware version is up to date: 0x26330500
11:12:00:443 Current channel 20
11:12:00:475 Device TTL 760 s flags: 0x7
11:13:00:440 Current channel 20
11:13:00:473 Device TTL 700 s flags: 0x7
11:13:01:882 send permit join, duration: 0
11:13:02:222 Announced to internet
11:13:02:223 discovery server date: Mon, 18 Nov 2019 09:13:02 GMT
11:13:02:223 local time seems to be ok
11:13:24:533 verified group capacity: 255 and group count: 1 of LightNode 0x000d6ffffee47b99
11:13:24:533 0x000d6ffffee47b99 found group 0xFFF0
11:13:26:037 verified group capacity: 255 and group count: 1 of LightNode 0x086bd7fffe1acc4d
11:13:26:038 0x086bd7fffe1acc4d found group 0xFFF0
11:13:27:882 binding for cluster 0x0000 of 0x000D6FFFFEE47B99 exists (verified by reporting)
11:13:27:882 binding for cluster 0x0006 of 0x000D6FFFFEE47B99 exists (verified by reporting)
11:13:29:159 Bind response success for 0x000d6ffffee47b99 cluster 0x0008
11:13:29:159 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x000D6FFFFEE47B99 (wait reading or unsupported)
11:13:29:687 ZCL configure reporting rsp seq: 140 0x000D6FFFFEE47B99 for cluster 0x0006 attr 0x0000 status 0x00
11:13:58:882 binding for cluster 0x0000 of 0x000D6FFFFEE85958 exists (verified by reporting)
11:13:58:882 binding for cluster 0x0006 of 0x000D6FFFFEE85958 exists (verified by reporting)
11:13:59:222 0x000D6FFFFEE85958 error APSDE-DATA.confirm: 0xE9 on task
11:13:59:431 Bind response success for 0x000d6ffffee85958 cluster 0x0008
11:13:59:431 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x000D6FFFFEE85958 (wait reading or unsupported)
11:14:00:359 ZCL configure reporting rsp seq: 142 0x000D6FFFFEE85958 for cluster 0x0006 attr 0x0000 status 0x00
11:14:00:455 Current channel 20
11:14:00:486 Device TTL 640 s flags: 0x7
11:14:00:711 verified group capacity: 255 and group count: 1 of LightNode 0x000d6ffffee85958
11:14:00:711 0x000d6ffffee85958 found group 0xFFF0
11:14:01:883 binding for cluster 0x0000 of 0x086BD7FFFE1ACC4D exists (verified by reporting)
11:14:01:883 binding for cluster 0x0006 of 0x086BD7FFFE1ACC4D exists (verified by reporting)
11:14:02:040 ZCL configure reporting rsp seq: 145 0x086BD7FFFE1ACC4D for cluster 0x0006 attr 0x0000 status 0x00
11:14:02:103 Bind response success for 0x086bd7fffe1acc4d cluster 0x0008
11:14:02:103 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x086BD7FFFE1ACC4D (wait reading or unsupported)
11:15:00:455 Current channel 20
11:15:00:486 Device TTL 580 s flags: 0x7
11:15:00:486 Device reset watchdog 7200 s
11:15:06:426 dev /dev/ttyAMA0
11:15:06:426 GW firmware version: 0x26330500
11:15:06:426 GW firmware version is up to date: 0x26330500
11:16:00:454 Current channel 20
11:16:00:485 Device TTL 7140 s flags: 0x7
11:17:00:451 Current channel 20
11:17:00:482 Device TTL 7080 s flags: 0x7
11:18:00:449 Current channel 20
11:18:00:482 Device TTL 7020 s flags: 0x7
11:18:01:235 no button map for: lumi.weather ep: 0x01 cl: 0x0402 cmd: 0x0A pl[0]: 000
11:18:01:235 ZCL attribute report 0x00158D000238CE37 for cluster 0x0402, ep 0x01
11:18:01:299 no button map for: lumi.weather ep: 0x01 cl: 0x0405 cmd: 0x0A pl[0]: 000
11:18:01:299 ZCL attribute report 0x00158D000238CE37 for cluster 0x0405, ep 0x01
11:18:01:331 no button map for: lumi.weather ep: 0x01 cl: 0x0403 cmd: 0x0A pl[0]: 000
noticed that it is the wrong time, it shows at 11, but it is 10:20!
