Hi, I have home assistant running with a Conbee 2 usb stick with a couple of Aqara sensors connected to it, including two motion sensors.
But for some reason the time the motions sensors is triggered when seeing any motion is too damn long, close to five minutes, is there any way to change the trigger time, maybe by a script of some sort?
Hi Tobias,
I have the same issue. My trigger time is not that long, but I would estimate about 30 sec. I have opened a new topic, because I also have the issue that there is no new trigger. If somebody stays in the room and the light switch off after a couple of minutes there is no new trigger to keep it on. Do you have a solution for that?
