Has anyone else had issues with deConz since upgrading to 2.0? It was working fine before, since upgrading when I go to the UI I can’t go any further as it continually loops bringing up the stick (none of which can be clicked through).
I’ve tried removing the add-on and re-installing, but that doesn’t make any difference. I’m on 0.91.3
I’ve not been able to downgrade because I’m running it in Docker under Hassio. I can get the 1.4 image, just can’t get it to load the container because Hassio insists on version 2.0.
That said, you can get to Phoscon UI by using the URL
<IP address of box with USB device connected>:40850
After a bit of shenanigans, I’ve been able to add back (I reset the gateway) in the individual sensors. So moral of the story is to have a backup of the config (doh!) before changing anything.
