deCONZ - Official thread
Stopped Hassio, and tried changing to False but it doesn’t remove the group entities ? Tried a restart too. No probs, I can wait for the update
If the entities are already in hass you also have to remove them in the entity registry, by going in the ui to Configuration -> Entity Registry, looking up the entity you want to remove, press it and press delete.
Thanks, that’s what I’ve done already, just needs doing every time I re-add the intergration (not that often!)
When you’ve changed the file as stated before you won’t have to do it again!
Why do you need to re-add the add-on? Change of address?
Some devices sometimes go offline and only way to bring them back online seems to be to delete and re-add the integration. Not re-adding the addon.
Next time it happens, can you enable debug for deconz component and share logs?
Yes sure will, thanks
I want to reinstall the official deconz addon. But I today I get this error:
19-05-05 10:57:50 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/armhf-addon-deconz tag 2.2.
19-05-05 10:58:28 ERROR (SyncWorker_1) [hassio.docker.interface] Can't install homeassistant/armhf-addon-deconz:2.2 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-addon-deconz:2.2: No such image: homeassistant/armhf-addon-deconz:2.2").
hi
can you explain in more detail? where to obtain that firmware? how to flash?
i only work with deconz, but i am interested in those “cheap” routers
also maybe a link where you bought them?
thnx in advance
I bought them off eBay - I am in the UK, but below are the links:
CC Debugger (needed to flash)
Zigbee Stick (2531)
You then need to flash the specific router firmware (not the standard coordinator)
Router Firmware
The instructions are here:
Flashing the CC2531
The flashing is quite easy.
Hope this helps!
mb
this helps, thnx for posting!
Just went from marthocs addon to the official one, is ingress broken for everyone?
AFAIK they removed ingress from deCONZ addon
I was using Zigbee2Mqtt with CC2531 and now I bought the Conbee II configured with official HA Addon deCONZ.
I have the integration with HA but I am missing the “battery”, “last_seen” and “link_quality” entities from the xiaomi sensors.
Any idea how I can show this entities with the Conbee II?
At least battery takes some time before being reported
Is link quality actually possible? I don’t see that info for my xiaomi either
Only through the GUI I believe.
yes, the colored lines
With zigbee2mqtt i was using this sensor:
platform: “mqtt”
name: “Camera Letto Link Quality”
state_topic: “zigbee2mqtt/zb_camera_letto”
unit_of_measurement: “%”
availability_topic: “zigbee2mqtt/bridge/state”
value_template: “{{ value_json.linkquality }}”
