So i’m pretty new to home assistant and all this stuff. I have two switches that use conbee and deconz. Today they just stopped working all of a sudden and in the devices tab it says “error connecting to deconz gateway”.
this seems like a common issue. So my question is do I have to reinstall sine there was a HA update? I didn’t even update yet, but maybe something still broke?
I have a zigbee network with 22 devices in HA with deconz and conbee 2. The problem is that a device (_TZ3000_tqlv4ug4) often loses coverage because of the range in which it is located, but the mysterious thing is that right next to that device I have a zigbee plug (_TZ3000_u5u4cakc) that is also a router, and that plug always has coverage despite how far it is, but the other device does not. I would like to know if I can somehow force the device that does not have coverage to connect to the socket and thus always have coverage.
This problem is still valid, now on version 6.20.0:
I have a problem with the deconz 6.19.0 update: All my IKEA Praktlysning shades stops responding and have disappeared from Phoscon. I’m not sure if other components are affected, but IKEA Tredansen still working.
After reverting to version 6.18.0 everything is working, but it takes a few minutes before the Praktlysning shades are back in business.
Hi there, I am running the following setup on a Raspberry Pi 4 + Phoscon RaspBee II:
Home Assistant 2023.9.1
Supervisor 2023.09.0
Operating System 10.5
Frontend 20230908.0 - latest
deCONZ Add-on version 6.20.0 (Phoscon firmware version 2.22.02)
I have 2 SONOFF ZBMINIL2 smart switches that I want to connect to HA. After a few tests with the first one (let’s call it switch1) without success I got it finally connected after moving it bit closer to the RPi (moved less than 2 meters from original location which is 6-7 meters away from RPi but on a 3rd room). Once connected if I move it back I can see signal is lost from deCONZ application through VNC.
So I though to take advantage of the mesh network installing the second ZBMINIL2 (let’s call it switch2) in the middle room (1st room RPi, 2nd room switch2, 3rd room switch1). switch2 is connected and works correctly but it looks like switch1 doesn’t want to route through switch2 to reach Raspbee II. How can I force that?
I enabled LQI and increased minimum value hoping to push switch1 to change its route. Also toggled “Fast neighbor discovery”. What else should I do?
Alright a few pages later and a few terms learned it seems that SONOFF ZBMINIL2 is an “end device” and not a “router” so it cannot do what I was hoping for. RaspBee II is the coordinator and end devices will just connect to that or to a router node.
This is also confirmed by the “node type” I can see from the node info in deCONZ application. Hope this helps someone else starting the journey of home automation like me.
But the last stable is the deconz-2.23.01 from 16.09.2023, but you can only install the old stable deconz-2.22.02 from 31.07.2023. When will this be updated?
I don’t use the addon myself but I know Frenck who I think typically manage bumping the addon has been on vacation recently so it might be on his backlog to do. Otherwise you can create an issue here GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant and make them aware that a new version is available.
This problem is still valid, now on version 6.22.0:
I have deCONZ working well with a conbee 2 device but I’m at the stage now where I need to act on device actions (physical light switch press) as soon as possible.
Within HA, virtual events work almost immediately, however physical events (switch press) take ~30 seconds until they are reflected in the HA.
Is this a per device/manufacture setting or some polling interval in deCONZ that is causing this delay? If so, where can it be changed? Devices in question are wiser (schneider) dimmer switches.
There is something very wrong if a button press from a zigbee switch takes 30 seconds to be seen by Home Assistant. It takes a fraction of a second. Otherwise noone could use Deconz/HA to do even simple automations like press a button to turn on light
Aa Kenneth writes it’s expected to be near instant. This was the primary reason I wrote the integration in the first place. I wanted to get a good user experience with using zigbee remotes.
Thanks both. Thats what I figured. I assume when I use a HA entity to toggle a light on/off that it is going through deCONZ to my conbee2 device to action this. That in itself works instantly. Its only if I tap the physical button that it can take up to 30 seconds before the HA entity will reflect the change.
Any tips on how I could better troubleshoot this? Is there anything in the deCONZ app which shows the connected graph of all the devices that I could look for?
So it seems that this is only to do with the lights I have. In HA and the DeCONZ app, sensors (door and motion sensors) update immediately in the both UI’s , however when I physically press the button (switch or dimmer switch) it can take 5-30 seconds to update in both HA and the deCONZ Phoscon app.
The USB device is now close by the devices (lights) and the motion sensors turn them on instantly as directed by them. Could it be the lights are more prone to signal interference/strength than the other devices? (Schneider Electric - CH/DIMMER/1 and CH2AX/SWITCH/1)
Yes, it a physical button (switch) that powers a light . The switch is connected via deCONZ / Conbee2.
When I press the physical button, it will turn toggle the light on/off, but that change will not reflect within HA for 10-30 seconds (i.e. entity card on a dashboard or entity in home kit)
The wiser sensors/ and other door/window sensors reflect changes in HA immediately, and within the deCONZ app, it is just these switches for some reason have a delay from the physical press.
