deCONZ - Official thread
I sent you a private message with the requested data for the Hue Tap and the Aqara Switch (not sure if it was in your list or not).
I already have for the 5 button one. Thanks for supporting though!
I should mention I capture them in NodeRed from deconz’s web socket. Hass doesn’t do anything with them. Is anything useful I can get for you in my setup?
I think I have the information I need for taps now.
Models and the four button events
I solved the problem…
So using the RaspBee i used
enable_uart=1
dtoverlay=pi3-miniuart-bt
in the config.txt
and used
  "device": "/dev/ttyAMA0",
  "vnc_password": "sth"
with the same hardware. My mistake was that i googled too much instead of just copy and paste the correct info from here. I accidentally used
dtoverlay=pi3-disable-bt
After this the firmware is shown and the vnc interface is working fine!
Edit: well maybe not… just restarting the raspberry and it doesn’t work anymore…
Just setup Deconz as docker image on my Synology NAS. No automations ye, but the sensors come through fine.
I have an aesthetic question :slight_smile:
I want to add DeconZ to my side panel, but I can’t get it to work. Like with Configurator and Node-red (which worked) I did the following:
deconz:
    title: DeconZ
    icon: mdi:zigbee
    url: 'http://<IP address>:8080'
It shows up in the side panel, but it won’t load. Is this because all other Hass stuff is running in https and only Deconz isn’t? Or am I doing something else wrongly?
Is your port correct, mine is 40850, the plugin default
Yes, I have no issues accessing it separately by going to http://:8080 in my browser.
I also tried based on this info How to deal with non-SSL Panel iframe pages inside SSL Hass.io environment?, but to no avail :frowning:
Seems there is an update available of deCONZ - with a fix for the Tradfri Motion Sensors.
Will try this this evening :slight_smile:
– Seems its only the hassio add-on that is updated. not the deCONZ docker image
If you have trouble with the deconz addon not being able to use /dev/serial/by-id/usb-… type device names then you need to know that from 3.4 there is a known issue for some users but not all.
The fix is to use the simple /dev/ttyACM0 or /dev/ttyACM1 device name. That is a bad fix if you have both ACM0 and ACM1 because it is a lottery which one is which when you boot
The developer refuses to fix the issue and closes the issues raised
I recommend you keep on raising new bug reports anyway.
I personally made another solution. I uninstalled the addon and instead installed the deconz software directly in the Ubuntu OS by adding the repo and installing with apt install. That actually also has the advantage that you get updates the minute they are posted. It is the beta channel you need to install to get same or newer versions than the addon
I just followed the instructions here https://github.com/dresden-elektronik/deconz-rest-plugin
That is not true. Sorry to hear you are having troubles, If we could reproduce it, we will do everything to fix it. Meanwhile, I would appreciate if do not draw conclusions and spread misinformation like that specific quote. That is helping nobody and is certainly not helping in getting developers excited to help you out as well.
@frenck - It is a fact that two bug reports were closed quickly unresolved. Several people reporting the same problem (plus people here on this forum thread). I have not been able to convince anyone to reopen them since. No dialog with me after they were closed. How else should I interpret the situation?
Why are both issues closed? I summarized what I know in the later of the two bug reports and there is plenty of debug info from me in the first. And as you will see in the reports I got stuck and asked for help. And I have a theory of what is wrong. And actually @frenck you raised a question to the developer on the exact git commit that caused the issue (3 second delay)
Inserting the Conbee stick into another USB-port sometimes solves this problem
I had the same issue when i updated to 3.3 and this solved me problem.
Hi Klumpke. I tried that also. But I could not see an improvement. Note that on my Celeron based NUC the serial/by-id fails about 6 of 10 starts of the deconz addon. I tried restarting more than a 100 times trying many things. I could improve the frequency by moving things around but it never got reliable.
As I write in the bug report I think the issue is this
When you start the deconz docker it runs the udev process first which rediscover the devices and create the serial links in /dev/serial/by-id that points to /dev/ttyACM#.
It then waits 3 seconds
Next it tests if the serial device in the config exists. If not it dies and the container stops. If yes it continues starting deconz. If it passes the test it always succeeds starting up. It always stops the same place.
In a recent deconz update the way udev is invoked what changed and the 3 second delay was added.
My theory is that the the new way takes longer to create the symlinks in /dev/serial/by-id and can fail to finish within the 3 seconds. I got stuck in my debugging because I am too dumb to understand how to change the sources and rebuild the docker image so it starts within Home Assistant realm.
If any of you with the issue is smarter than me - with respect to docker - try and increase the 3 second timeout and see if the issue is resolved.
But I also again want to refer to the possibility to run the addon on “bare metal”. Running deconz on the Linux host OS, or on a different machine (can be a Raspberry Pi) has advantages. You always get the latest version with “apt update” and “apt upgrade” without waiting for the addon to catch up. Deconz and your zigbee network does not restart when you restart HA. But it is naturally not as easy as clicking the install button in the HA addon store. But it is an alternative which is what I chose to go with now.
And I must say that I LOVE deconz. It is rock solid stable for me. I just moved 35 lights, and 15 dimmers, and 2 taps, from Philips Hue to deconz where I already had 20 or so zigbee sensors and sockets. And it is rock solid. I love it. And totally depend on it now which is a bit scary
Incorrect, the question I raised there was to avoid the delay and only induce it if needed.
I did not imply your comment was related to the issue. Sorry if it could be understood that way. Just a reminder to you which 3 seconds we are talking about.
It cannot be the 3 seconds that created the issue. The old code had no delay.
We can see the udev is invoked a different way. Maybe this alternative way does not create the symlinks as fast as the old code which is why the 3 seconds was added? And if that is the case your idea in the comment is interesting. It would run faster if a machine runs udev fast and it will wait if there is something that slows down the udev device discovery. We just cannot wait forever because a typing mistake in the deconz config and thing would hang forever
my 5 cents
well after watching @frenck live show
i got the
dresden elektronik ConBee II The Universal Zigbee USB Gateway
went to our mitre10 kiwi here (home depot)
got the hue light with dimmer Switch
plug the conbee II in with a long lead so not close to computer
when to system
install the deCONZ addon
pasted that long text into the config
plug the hue light in pres the I O at the same time light flash
and it peared happer camper
with the dimmer on back press the setup back to the phoscon app did the added the switch
and that work very happy camper
got some Xiaomi door switch and the Magic Cude (which is f… alsum.)
pair them now this was a couple month ago the next day both Xiaomi stop working :frowning:
re pair same couple days later stop working
googling did nothing gave up
last week sour there was update for the deCONZ addon did the update rebooted everything
hue stuff still work :slight_smile:
repaired the
they have not miss a beat yeat
so thanks guys for the hard work you guys have done
:beers:
Has anyone been able to get xiaomi vibration sensor to work with deconz? Ive added it in phoscon and it appears as a binary_sensor in home assistant but can not use events with it like the other switches.
Advise is appreciated.
Why can’t you use events?
No events shows up.
