deCONZ - Official thread
Hi, yeah I got them added… Used a paper clip to reset the sockets and then searched for lights (as Dixey advised) they all added OK, to get them into HA I had to manually add it while setting the api to be visible (had to do this about 4 times though) all worked untill last night… No nothing works… I think my conbee may be drunk… So I’ll let it sober up before I mess about some more… :wink:
I’m using Raspbee, did not add any new hardware and my Zigbee Network is on a different channel.
The cover is on the second floor, whereas my raspbee is in the basement. Nevertheless there are plenty of lights and switches in between and the Hue Lightstrips in the same room are working fine…
(Rebooting HA didn’t solve the issue and btw, I’m still on version 3.8)
And another thing: I’m currently trying to add a Osram LED strip…
  • I reseted the strip using my Hue tap (holding on & off for 10 seconds, waiting until the strip blinked 3 times)
  • I unplugged the strip and started the search for new lights in the web interface
  • I plugged in the strip, the strip flashed one time, but no new device is showing up in the web interface
  • In VNC I can see the device, it’s even connected to another node. Are there any further possibilities to get the device to join my network via VNC?
    Unbenannt
It happens to take some time to showing up in HA. Try to restart HA and/or deconz
I use deconz, I have around 20 devices from various manufacturers - including a fyrtur blind. I also have 15 sensors.
I do restart ha a fair amount, mostly 'cos I’m always adding things to it. I can’t remember the last time I restarted deconz except for when I update it.
I’ve had the fyrtur since the week it was first available in the UK, 4 months maybe?
I’ve had to remove the battery once to get it to reconnect. Another time I had to physically turn off (and back on) the kitchen lights that it uses as a router. Other than that it’s worked solidly.
My blind is two floors down from my deconz box, but like you, I have a number of powered devices routing between.
What version of deconz are you on, they are always fixing bugs.
Somehow the 2 Hassio have to see each other, so maybe in the main Hassio there is some configuration to be added but not sure how
Hi all… I’m having a problem but I don’t know if its in deCONZ, HA or my conbee 2 stick…
I have the conbee 2 stick installed and “working” via deCONZ, all my lights, switches and sockets are paired and were working fine…
I upgraded HA via the hass.io tab and ever since nothing is working… If I go into the deCONZ tab and log in all my lights and such are there but they don’t work… What’s happend and how do I correct it?
I’ve restarted HA a few times… Restarted deCONZ a few times also, nothing appears to make a difference…
Please help
Anything in logs?
In my case they recognized each other automatically before these updates. Is there any way to manually integrate Deconz by selecting IP and port?
Yes. If discovery fails during setup you will be prompted to manually input host and port.
I cannot find a way to manually input host or port. Since Deconz is not discovered automatically I push on “+” button in the integrations page and select Deconz. However it only gives me a prompt to unlock the GW and then push submit and no option to manually input host/port. When unlocking the GW in Phoscon and pressing “Submit” I only get “unknown error occurred”… what am I doing wrong?
Make sure to turn off deconz else it will be discovered
For everyone who is interested in or has stability problems with unavailable devices:
Since moving from Hue to deconz with my 30 bulbs, 6 motion sensors and some switches I faced the problem, that some bulbs became unavailable mostly in the morning and late afternoon.
I changed the channel, used an extension cable but nothing helped.
Then I found a thread regarding compatibility of Pi 4 and Conbee.
One guy there used a powerd usb2.0 hub between the stick and the P4 in order to fix his availability problems.
I thought, that it is worth a test for my problem as well and was lucky to find an old, powered, hub in my “electric waste”
I plugged it between the extension cable and the conbee 3 days ago and since that time, the complete system is running stable without any unavailabilities.
If some of you have stability problems, a powerd usb hub may help, for what reason ever.
hi Vasco, thank you for your reply.
in the logs tab there is nothing, and under the developer tools --> logs there is also nothing showing up, however if I go into the log file via samba i have the below… (though i can’t make head nor tail of it so good luck)
2020-01-02 00:01:05 INFO (MainThread) [homeassistant.setup] Setting up deconz
2020-01-02 00:01:05 INFO (MainThread) [homeassistant.setup] Setup of domain deconz took 0.0 seconds.
further down i have
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.utils] HTTP request response: {'config': {'UTC': '2020-01-02T00:01:11', 'apiversion': '1.16.0', 'backup': {'errorcode': 0, 'status': 'idle'}, 'bridgeid': '00212EFFFF0507D7', 'datastoreversion': '60', 'devicename': 'ConBee II', 'dhcp': True, 'factorynew': False, 'fwversion': '0x264a0700', 'gateway': '172.30.**.*', 'internetservices': {'remoteaccess': 'disconnected'}, 'ipaddress': '172.30.**.*', 'linkbutton': False, 'localtime': '2020-01-02T00:01:11', 'mac': '02:42:ac:**:**:**', 'modelid': 'deCONZ', 'name': 'Conbee 2', 'netmask': '255.255.254.0', 'networkopenduration': 60, 'panid': 27168, 'portalconnection': 'disconnected', 'portalservices': False, 'portalstate': {'communication': 'disconnected', 'incoming': False, 'outgoing': False, 'signedon': False}, 'proxyaddress': 'none', 'proxyport': 0, 'replacesbridgeid': None, 'rfconnected': True, 'starterkitid': '', 'swupdate': {'checkforupdate': False, 'devicetypes': {'bridge': False, 'lights': [], 'sensors': []}, 'notify': False, 'text': '', 'updatestate': 0, 'url': ''}, 'swupdate2': {'autoinstall': {'on': False, 'updatetime': ''}, 'bridge': {'lastinstall': '2019-12-12T11:40:44', 'state': 'allreadytoinstall'}, 'checkforupdate': False, 'install': False, 'lastchange': '', 'lastinstall': '', 'state': 'allreadytoinstall'}, 'swversion': '2.5.72', 'timeformat': '24h', 'timezone': 'Europe/London', 'uuid': '********-c53a-4e17-a0fa-0e787e1a0453', 'websocketnotifyall': True, 'websocketport': 8081, 'whitelist': {'0B291D2AE4': {'create date': '2019-12-27T11:15:44', 'last use date': '2019-12-27T11:29:46', 'name': 'Phoscon#B718x608'}, '20E9D0A34D': {'create date': '2019-12-27T13:51:25', 'last use date': '2019-12-27T17:45:58', 'name': 'pydeconz'}, '218F1E840E': {'create date': '2019-12-28T18:04:55', 'last use date': '2019-12-28T21:34:16', 'name': 'Phoscon#S818x740'}, '26D048C310': {'create date': '2019-12-27T12:14:07', 'last use date': '2019-12-27T21:39:58', 'name': 'Phoscon#S1262x780'}, '3BAAFD6D1D': {'create date': '2019-12-27T11:17:44', 'last use date': '2019-12-27T11:26:07', 'name': 'pydeconz'}, '3F4B4C7747': {'create date': '2020-01-01T02:31:49', 'last use date': '2020-01-01T02:38:42', 'name': 'Phoscon#S360x720'}, '56478788EA': {'create date': '2019-12-27T21:20:51', 'last use date': '2020-01-02T00:01:11', 'name': 'Home Assistant'}, '5F65460B45': {'create date': '2019-12-27T10:06:58', 'last use date': '2019-12-27T22:28:50', 'name': 'Phoscon#S360x480'}, '6685CDD3D4': {'create date': '2019-12-27T13:49:55', 'last use date': '2019-12-27T17:32:41', 'name': 'Phoscon#B1110x625'}, '6F01E1FB58': {'create date': '2020-01-01T23:55:34', 'last use date': '2020-01-01T23:56:37', 'name': 'Phoscon#S360x472'}, '75FF4C1099': {'create date': '2019-12-26T15:12:48', 'last use date': '2019-12-26T20:41:49', 'name': 'Phoscon#S1262x780'}, '76E5FBCFE1': {'create date': '2019-12-27T12:29:44', 'last use date': '2019-12-27T13:37:37', 'name': 'pydeconz'}, '7EF7B4947C': {'create date': '2019-12-26T21:29:13', 'last use date': '2019-12-26T22:01:26', 'name': 'Phoscon#S360x480'}, '846FE9C183': {'create date': '2020-01-01T11:27:38', 'last use date': '2020-01-01T14:58:28', 'name': 'Phoscon#S360x472'}, '99742D7F5B': {'create date': '2020-01-01T10:53:49', 'last use date': '2020-01-01T10:59:17', 'name': 'Phoscon#S360x424'}, 'C30C947ACE': {'create date': '2019-12-27T20:56:19', 'last use date': '2019-12-27T20:56:19', 'name': 'pydeconz'}, 'E9A472B581': {'create date': '2019-12-27T10:45:09', 'last use date': '2019-12-27T11:29:44', 'name': 'Phoscon#S1262x780'}, 'F48A1F8348': {'create date': '2020-01-01T15:26:58', 'last use date': '2020-01-01T15:29:38', 'name': 'Phoscon#S360x480'}, 'F7F39D0821': {'create date': '2019-12-26T21:09:08', 'last use date': '2019-12-26T21:17:12', 'name': 'Phoscon#S1262x780'}}, 'zigbeechannel': 11}, 'groups': {'1': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': [], 'etag': '931ab4180fce279c3fa101171676788f', 'id': '1', 'lights': ['2', '3', '1'], 'name': 'Lounge main lights', 'scenes': [{'id': '1', 'lightcount': 3, 'name': 'Tv', 'transitiontime': 10}, {'id': '2', 'lightcount': 3, 'name': 'Work', 'transitiontime': 200}], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}, '21144': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': ['2'], 'etag': '931ab4180fce279c3fa101171676788f', 'id': '21144', 'lights': [], 'name': 'TRADFRI wireless dimmer 2', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}, '26853': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': ['4'], 'etag': '931ab4180fce279c3fa101171676788f', 'id': '26853', 'lights': [], 'name': 'TRADFRI wireless dimmer 9', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}, '3': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': [], 'etag': '9815d415d9479dc9b9f4542e409f4211', 'id': '3', 'lights': ['4', '5', '12'], 'name': 'Lounge lamps', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}, '5': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': [], 'etag': '931ab4180fce279c3fa101171676788f', 'id': '5', 'lights': ['7'], 'name': 'Bedside Robin', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}, '53392': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': ['6'], 'etag': '931ab4180fce279c3fa101171676788f', 'id': '53392', 'lights': [], 'name': 'TRADFRI wireless dimmer 11', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}, '6': {'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': [], 'etag': '931ab4180fce279c3fa101171676788f', 'id': '6', 'lights': ['8'], 'name': 'Bedside Elsbeth', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}}, 'lights': {'1': {'etag': 'd214b01d19458964ac32829a75eab220', 'hascolor': False, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb E14 W op/ch 400lm', 'name': 'Lounge main light 1', 'state': {'alert': 'none', 'bri': 30, 'on': True, 'reachable': False}, 'swversion': '1.2.214', 'type': 'Dimmable light', 'uniqueid': '00:0b:57:ff:fe:a4:ce:29-01'}, '12': {'etag': '9815d415d9479dc9b9f4542e409f4211', 'hascolor': False, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI control outlet', 'name': 'Corner Lamp', 'state': {'alert': 'none', 'on': False, 'reachable': False}, 'swversion': '2.0.022', 'type': 'On/Off plug-in unit', 'uniqueid': '00:0d:6f:ff:fe:dc:56:42-01'}, '2': {'etag': 'd214b01d19458964ac32829a75eab220', 'hascolor': False, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb E14 W op/ch 400lm', 'name': 'Lounge main light 2', 'state': {'alert': 'none', 'bri': 30, 'on': True, 'reachable': False}, 'swversion': '1.2.214', 'type': 'Dimmable light', 'uniqueid': '00:0b:57:ff:fe:8c:bc:ff-01'}, '3': {'etag': 'd214b01d19458964ac32829a75eab220', 'hascolor': False, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb E14 W op/ch 400lm', 'name': 'Lounge main light 3', 'state': {'alert': 'none', 'bri': 30, 'on': True, 'reachable': False}, 'swversion': '1.2.214', 'type': 'Dimmable light', 'uniqueid': '00:0b:57:ff:fe:8d:06:45-01'}, '4': {'etag': '9815d415d9479dc9b9f4542e409f4211', 'hascolor': False, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI control outlet', 'name': 'Christmas Tree', 'state': {'alert': 'none', 'on': False, 'reachable': False}, 'swversion': '2.0.022', 'type': 'On/Off plug-in unit', 'uniqueid': '00:0d:6f:ff:fe:da:e0:d4-01'}, '5': {'etag': '9815d415d9479dc9b9f4542e409f4211', 'hascolor': False, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI control outlet', 'name': 'Tall lamp', 'state': {'alert': 'none', 'on': False, 'reachable': False}, 'swversion': '2.0.022', 'type': 'On/Off plug-in unit', 'uniqueid': '00:0d:6f:ff:fe:d2:20:61-01'}, '7': {'ctmax': 454, 'ctmin': 250, 'etag': 'd214b01d19458964ac32829a75eab220', 'hascolor': True, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb E14 WS opal 400lm', 'name': 'Bedside 1', 'state': {'alert': 'none', 'bri': 30, 'colormode': 'xy', 'ct': 250, 'on': False, 'reachable': False}, 'swversion': '1.2.221', 'type': 'Color temperature light', 'uniqueid': '90:fd:9f:ff:fe:8e:1e:f1-01'}, '8': {'ctmax': 454, 'ctmin': 250, 'etag': 'd214b01d19458964ac32829a75eab220', 'hascolor': True, 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb E14 WS opal 400lm', 'name': 'bedside 2', 'state': {'alert': 'none', 'bri': 30, 'colormode': 'xy', 'ct': 454, 'on': False, 'reachable': False}, 'swversion': '1.2.221', 'type': 'Color temperature light', 'uniqueid': '90:fd:9f:ff:fe:d3:0b:7e-01'}}, 'resourcelinks': {}, 'rules': {}, 'scenes': {}, 'schedules': {}, 'sensors': {'1': {'config': {'configured': True, 'on': True, 'sunriseoffset': 30, 'sunsetoffset': -30}, 'etag': '931ab4180fce279c3fa101171676788f', 'manufacturername': 'Philips', 'modelid': 'PHDL00', 'name': 'Daylight', 'state': {'dark': True, 'daylight': False, 'lastupdated': '2020-01-01T18:14:59', 'status': 230, 'sunrise': '2020-01-01T08:48:38', 'sunset': '2020-01-01T15:54:32'}, 'swversion': '1.0', 'type': 'Daylight', 'uniqueid': '00:21:2e:ff:ff:05:07:d7-01'}, '2': {'config': {'alert': 'none', 'battery': 60, 'group': '21144', 'on': True, 'reachable': False}, 'ep': 1, 'etag': '931ab4180fce279c3fa101171676788f', 'manufacturername': 'IKEA of Sweden', 'mode': 4, 'modelid': 'TRADFRI wireless dimmer', 'name': 'wireless dimmer lounge', 'state': {'buttonevent': 2002, 'lastupdated': '2019-12-27T21:40:54'}, 'swversion': '1.2.248', 'type': 'ZHASwitch', 'uniqueid': '00:0b:57:ff:fe:91:c0:50-01-1000'}, '4': {'config': {'alert': 'none', 'battery': 60, 'group': '26853', 'on': True, 'reachable': False}, 'ep': 1, 'etag': '931ab4180fce279c3fa101171676788f', 'manufacturername': 'IKEA of Sweden', 'mode': 4, 'modelid': 'TRADFRI wireless dimmer', 'name': 'Robins dimmer', 'state': {'buttonevent': 3002, 'lastupdated': '2019-12-30T20:56:45'}, 'swversion': '1.2.248', 'type': 'ZHASwitch', 'uniqueid': '00:0b:57:ff:fe:15:0c:5b-01-1000'}, '6': {'config': {'alert': 'none', 'battery': 60, 'group': '53392', 'on': True, 'reachable': True}, 'ep': 1, 'etag': '931ab4180fce279c3fa101171676788f', 'manufacturername': 'IKEA of Sweden', 'mode': 4, 'modelid': 'TRADFRI wireless dimmer', 'name': 'Elsbeths Dimmer', 'state': {'buttonevent': 3002, 'lastupdated': '2020-01-01T00:59:00'}, 'swversion': '1.2.248', 'type': 'ZHASwitch', 'uniqueid': '00:0b:57:ff:fe:2b:89:d5-01-1000'}}}
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz] {'config': {'UTC': '2020-01-02T00:01:11',
            'dhcp': True,
            'name': 'Conbee 2',
            'panid': 27168,
                            'incoming': False,
                            'outgoing': False,
                            'signedon': False},
            'proxyport': 0,
            'starterkitid': '',
                                         'lights': [],
                                         'sensors': []},
                         'notify': False,
                         'text': '',
                         'updatestate': 0,
                         'url': ''},
                          'install': False,
                          'lastchange': '',
                          'lastinstall': '',
            'uuid': '4c67e3ae-c53a-4e17-a0fa-0e787e1a0453',
                             'colormode': 'hs',
                             'ct': 0,
                             'effect': 'none',
                             'hue': 0,
                             'on': False,
                             'sat': 127,
                             'scene': None,
                             'xy': [0, 0]},
                  'id': '1',
                              'lightcount': 3,
                              'name': 'Tv',
                             {'id': '2',
                              'lightcount': 3,
                              'name': 'Work',
                                 'colormode': 'hs',
                                 'ct': 0,
                                 'effect': 'none',
                                 'hue': 0,
                                 'on': False,
                                 'sat': 127,
                                 'scene': None,
                                 'xy': [0, 0]},
                      'id': '21144',
                      'lights': [],
                      'scenes': [],
                                 'colormode': 'hs',
                                 'ct': 0,
                                 'effect': 'none',
                                 'hue': 0,
                                 'on': False,
                                 'sat': 127,
                                 'scene': None,
                                 'xy': [0, 0]},
                      'id': '26853',
                      'lights': [],
                      'scenes': [],
                             'colormode': 'hs',
                             'ct': 0,
                             'effect': 'none',
                             'hue': 0,
                             'on': False,
                             'sat': 127,
                             'scene': None,
                             'xy': [0, 0]},
                  'id': '3',
                  'scenes': [],
                             'colormode': 'hs',
                             'ct': 0,
                             'effect': 'none',
                             'hue': 0,
                             'on': False,
                             'sat': 127,
                             'scene': None,
                             'xy': [0, 0]},
                  'id': '5',
                  'lights': ['7'],
                  'scenes': [],
                                 'colormode': 'hs',
                                 'ct': 0,
                                 'effect': 'none',
                                 'hue': 0,
                                 'on': False,
                                 'sat': 127,
                                 'scene': None,
                                 'xy': [0, 0]},
                      'id': '53392',
                      'lights': [],
                      'scenes': [],
                             'colormode': 'hs',
                             'ct': 0,
                             'effect': 'none',
                             'hue': 0,
                             'on': False,
                             'sat': 127,
                             'scene': None,
                             'xy': [0, 0]},
                  'id': '6',
                  'lights': ['8'],
                  'scenes': [],
                  'hascolor': False,
                            'bri': 30,
                            'on': True,
                   'hascolor': False,
                  'hascolor': False,
                            'bri': 30,
                            'on': True,
                  'hascolor': False,
                            'bri': 30,
                            'on': True,
                  'hascolor': False,
                  'hascolor': False,
            '7': {'ctmax': 454,
                  'ctmin': 250,
                  'hascolor': True,
                            'bri': 30,
                            'colormode': 'xy',
                            'ct': 250,
                            'on': False,
            '8': {'ctmax': 454,
                  'ctmin': 250,
                  'hascolor': True,
                            'bri': 30,
                            'colormode': 'xy',
                            'ct': 454,
                            'on': False,
please see next post for the rest of the log (it was to long to be in one post)
here is the rest of the log (it was to long to be allowed in one post)
 'rules': {},
 'scenes': {},
 'schedules': {},
                              'on': True,
                   'name': 'Daylight',
                             'daylight': False,
                             'status': 230,
                   'swversion': '1.0',
                   'type': 'Daylight',
                              'battery': 60,
                              'group': '21144',
                              'on': True,
                   'ep': 1,
                   'mode': 4,
                              'battery': 60,
                              'group': '26853',
                              'on': True,
                   'ep': 1,
                   'mode': 4,
                              'battery': 60,
                              'group': '53392',
                              'on': True,
                              'reachable': True},
                   'ep': 1,
                   'mode': 4,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Lounge main lights created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '1',
            {'id': '2',
             'lightcount': 3,
             'name': 'Work',
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] TRADFRI wireless dimmer 2 created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '21144',
 'lights': [],
 'scenes': [],
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] TRADFRI wireless dimmer 9 created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '26853',
 'lights': [],
 'scenes': [],
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Lounge lamps created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '3',
 'scenes': [],
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Bedside Robin created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '5',
 'lights': ['7'],
 'scenes': [],
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] TRADFRI wireless dimmer 11 created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '53392',
 'lights': [],
 'scenes': [],
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Bedside Elsbeth created as
            'colormode': 'hs',
            'ct': 0,
            'effect': 'none',
            'hue': 0,
            'on': False,
            'sat': 127,
            'scene': None,
            'xy': [0, 0]},
 'id': '6',
 'lights': ['8'],
 'scenes': [],
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Lounge main light 1 created as
 'hascolor': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Corner Lamp created as
 'hascolor': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Lounge main light 2 created as
 'hascolor': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Lounge main light 3 created as
 'hascolor': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Christmas Tree created as
 'hascolor': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Tall lamp created as
 'hascolor': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Bedside 1 created as
{'ctmax': 454,
 'ctmin': 250,
 'hascolor': True,
           'bri': 30,
           'colormode': 'xy',
           'ct': 250,
           'on': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] bedside 2 created as
{'ctmax': 454,
 'ctmin': 250,
 'hascolor': True,
           'bri': 30,
           'colormode': 'xy',
           'ct': 454,
           'on': False,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Daylight created as
            'on': True,
 'name': 'Daylight',
           'daylight': False,
           'status': 230,
 'swversion': '1.0',
 'type': 'Daylight',
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] wireless dimmer lounge created as
            'battery': 60,
            'group': '21144',
            'on': True,
 'ep': 1,
 'mode': 4,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Robins dimmer created as
            'battery': 60,
            'group': '26853',
            'on': True,
 'ep': 1,
 'mode': 4,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.deconzdevice] Elsbeths Dimmer created as
            'battery': 60,
            'group': '53392',
            'on': True,
            'reachable': True},
 'ep': 1,
 'mode': 4,
2020-01-02 00:01:12 DEBUG (MainThread) [pydeconz.websocket] Websocket starting
further down …
2020-01-02 00:01:18 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: wireless_dimmer_lounge
2020-01-02 00:01:18 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: robins_dimmer
2020-01-02 00:01:18 DEBUG (MainThread) [homeassistant.components.deconz] deCONZ event created: elsbeths_dimmer
and
2020-01-02 00:22:09 DEBUG (MainThread) [pydeconz.websocket] Websocket data: {"e":"changed","id":"1","r":"sensors","state":{"dark":true,"daylight":false,"lastupdated":"2020-01-02T00:22:09","status":100,"sunrise":"2020-01-02T08:48:23","sunset":"2020-01-02T15:55:42"},"t":"event","uniqueid":"00:21:2e:ff:ff:05:07:d7-01"}
2020-01-02 08:48:29 DEBUG (MainThread) [pydeconz.websocket] Websocket data: {"e":"changed","id":"1","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-01-02T08:48:29","status":140,"sunrise":"2020-01-02T08:48:23","sunset":"2020-01-02T15:55:42"},"t":"event","uniqueid":"00:21:2e:ff:ff:05:07:d7-01"}
2020-01-02 08:53:39 DEBUG (MainThread) [pydeconz.websocket] Websocket data: {"e":"changed","id":"1","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-01-02T08:53:39","status":150,"sunrise":"2020-01-02T08:48:23","sunset":"2020-01-02T15:55:42"},"t":"event","uniqueid":"00:21:2e:ff:ff:05:07:d7-01"}
thats it… hope it makes some sense to you… its just text to me…
thank you for your help and time.
It’s USB 3.0 that causes interference, as I and probably others posted already.
Oh, haven"t found them. Then it is clear.
It would be Helpful for new users, to have an advice available in the installation guides.
Thanks for your help.
It’s also a pretty long thread now :slightly_smiling_face:
Totally agree on this. Can you do a PR to get this included in the docs?
Hi folks!
Trying to get my combo of conbee II, odroid N2 (usb3…) with coreElec going.
I have got homeassistant rolling, however, got trouble finding my tradfri bulbs.
It works in windows though! (usb3) Hooray! (so its not a dead stick at least)
I can easily find the lights and connect and they work as far as they dim when you click on em in phoscon.
> Bus 001 Device 010: ID 1cf1:0030 Dresden Elektronik
> docker logs deconz
> f[marthoc/deconz] Starting deCONZ...
> [marthoc/deconz] Current deCONZ version: 2.05.72
> [marthoc/deconz] Web UI port: 80
> [marthoc/deconz] Websockets port: 443
> [marthoc/deconz] VNC Disabled
> libpng warning: iCCP: known incorrect sRGB profile
> This plugin does not support propagateSizeHints()
> 19:42:25:464 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/deCONZ/webapp/
> 19:42:25:470 CTRL. 3.16.219:42:25:511 ZCLDB init file /root/.local/share/dresden-elektronik/deCONZ/zcldb.txt
> 19:42:25:624 parent process /bin/sh
> 19:42:25:624 gw run mode: normal
> 19:42:25:624 GW sd-card image version file does not exist: /root/.local/share/dresden-elektronik/deCONZ/gw-version
> 19:42:25:624 sd-card cid: 150100414a54443452ffffffffd36600
> 19:42:25:625 DB sqlite version 3.16.2
> 19:42:25:626 DB PRAGMA page_count: 30
> 19:42:25:626 DB PRAGMA page_size: 4096
> 19:42:25:626 DB PRAGMA freelist_count: 0
> 19:42:25:626 DB file size 122880 bytes, free pages 0
> 19:42:25:626 DB PRAGMA user_version: 6
> 19:42:25:626 DB cleanup
> 19:42:25:626 DB create temporary views
> 19:42:25:631 don't close database yet, keep open for 900 seconds
> 18:42:25:632 started websocket server at port 443
> 18:42:25:637 found node plugin: libde_rest_plugin.so - REST API Plugin
> 18:42:25:639 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
> 18:42:25:648 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
> 18:42:31:621 Announced to internet http://dresden-light.appspot.com/discover
> 18:42:31:621 discovery server date: Thu, 02 Jan 2020 18:42:31 GMT
> 18:42:31:621     local time seems to be ok
> 18:42:31:621 discovery found version 2.04.35 for update channel stable
> 18:42:32:196 New websocket 192.168.1.2:58830 (state: 3)
> 18:42:32:731 wait reconnect 9 seconds
> 18:42:33:731 wait reconnect 8 seconds
> 18:42:34:731 wait reconnect 7 seconds
> 18:42:35:117 New websocket 192.168.1.3:44258 (state: 3)
> 18:42:40:765 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26490700.bin.GCF`
Worst case, is it possible to have a conbee II gateway on one SBC and home assistant on another SBC?
