Same as @aleksander.lyse’s Deconz - Philips Hue Dimmer Switch (RWL021) but allows for RWL020 (US).
blueprint:
name: Deconz - Philips Hue Dimmer Switch
description: |
Control lights with a Philips Hue Dimmer Switch.
The top "on" button will turn the lights on to the last set brightness
(unless the force brightness is toggled on in the blueprint).
Dim up/down buttons will change the brightness smoothly and can be pressed
and hold until the brightness is satisfactory.
The bottom "off" button will turn the lights off.
domain: automation
input:
remote:
description: The remote to use
selector:
device:
integration: deconz
manufacturer: Philips
entity:
domain: sensor
device_class: battery
light:
description: The light(s) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description: >
Force the brightness to the set level below, when the "on" button on
the remote is pushed and lights turn on.
default: false
selector:
boolean:
brightness:
description: Brightness of the light(s) when turning on
default: 100
selector:
number:
min: 0
max: 100
mode: slider
step: 1
unit_of_measurement: "%"
mode: restart
max_exceeded: silent
variables:
force_brightness: !input force_brightness
- platform: event
event_type: deconz_event
event_data:
device_id: !input remote
- variables:
event: "{{ trigger.event.data.event }}"
- choose:
- conditions:
- "{{ event == 1000 }}"
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.turn_on
target: !input light
transition: 1
brightness_pct: !input brightness
default:
transition: 1
- conditions:
- "{{ event == 4000 }}"
sequence:
- service: light.turn_off
transition: 1
# Raise Dim
# Press
- conditions:
- "{{ event == 2000 }}"
sequence:
brightness_step_pct: 10
transition: 1
# Hold
- conditions:
- "{{ event == 2001 }}"
sequence:
brightness_step_pct: 25
transition: 1
# Lower Dim
# Press
- conditions:
- "{{ event == 3000 }}"
sequence:
brightness_step_pct: -10
transition: 1
# Hold
- conditions:
- "{{ event == 3001 }}"
sequence:
brightness_step_pct: -25
transition: 1
