It works right out of the box, but I have major reliability issues with it, it is only like 50-70% of the time when I push a dimmer button that it is registrered by deconz/home assistant and I am standing right by the conbee stick, so mesh/network shouldn’t be a problem. The rest of my setup with Hue and Trådfri bulbs work fine.
Anyone having experience with the Hue dimmer and deconz and whether that is working reliable?
I moved from my Pi3 to a laptop and suddenly all my problems with the reliability with deconz went away. It has now been rock solid for a very long time.
I don’t know WHY it has been working since I moved to a laptop. I am suspecting that there somehow was some interference with my Conbee stick sitting right next to my z wave stick or some thing else. I did’t change anything in my configuration, just moved to another device.
I don’t know if that is of much help, but if you haven’t already tried it an extension cord from the Pi might be worth a try, if it is due to interference somehow.
I am having a bit of a different issue… I was able to add the dimmer switch with no issue using the ConBee web app. However one back inside of Hass.io I am unable to add the dimmer switch as any kind of trigger… I am only able to trigger events based of the dimmer switch’s battery level. I need to be able to trigger an event off of button 1, 2, 3 or 4. Help?
