deCONZ - Philips Hue Tap Dial Switch by SmartHomeGeeks.io
Integrate the Philips Hue Tap Dial Switch into Home Assistant to create a powerful remote control, supporting single tap, double tap, hold, and conditional rotate functionality. (deCONZ version, Zigbee2MQTT version here)
This blueprint originated from an automation example that received a lot of love from the Home Assistant community. Given its popularity, we chose to enhance it further and convert it into a user-friendly blueprint.
For more information, visit: SmartHomeGeeks.io
blueprint:
  name: deCONZ (Phoscon) - Philips Hue Tap Dial Switch by SmartHomeGeeks.io
  author: SmartHomeGeeks.io
  description: Integrate Philips Hue Tap Dial Switch into Home Assistant to create
    rotate functionality. <br><br> **For more information, visit:** [SmartHomeGeeks.io](https://smarthomegeeks.io/hue-tap-dial-switch/)
  domain: automation
  input:
    device:
      name: Philips Hue Tap Dial Switch
      selector:
        device:
          filter:
            - integration: deconz
              model: RDM002
    tap_counter:
      description: Create a counter helper within Home Assistant to monitor the number
        of button presses on the switch, distinguishing between single and multiple
        clicks. This helper can be used for various switches, provided that they are
        not pressed at the same time
      selector:
        entity:
          domain:
          - counter
          multiple: false
    last_pressed:
      name: Last Pressed Input Text Helper
      description: Create an input text helper within Home Assistant to keep track
        of the last button pressed. This will facilitate implementing different rotation
        actions based on the last button pressed. **Each switch requires a unique
        helper!**
      selector:
        entity:
          domain:
          - input_text
          multiple: false
    button_1_single_press:
      name: Button 1 Single Press
      default: []
      selector:
        action: {}
    button_1_double_press:
      name: Button 1 Double Press
      default: []
      selector:
        action: {}
    button_1_hold:
      name: Button 1 Hold
      default: []
      selector:
        action: {}
    button_1_rotate_clockwise:
      name: Button 1 Rotate Clockwise
      default: []
      selector:
        action: {}
    button_1_rotate_counter_clockwise:
      name: Button 1 Rotate Counter-Clockwise
      default: []
      selector:
        action: {}
    button_2_single_press:
      name: Button 2 Single Press
      default: []
      selector:
        action: {}
    button_2_double_press:
      name: Button 2 Double Press
      default: []
      selector:
        action: {}
    button_2_hold:
      name: Button 2 Hold
      default: []
      selector:
        action: {}
    button_2_rotate_clockwise:
      name: Button 2 Rotate Clockwise
      default: []
      selector:
        action: {}
    button_2_rotate_counter_clockwise:
      name: Button 2 Rotate Counter-Clockwise
      default: []
      selector:
        action: {}
    button_3_single_press:
      name: Button 3 Single Press
      default: []
      selector:
        action: {}
    button_3_double_press:
      name: Button 3 Double Press
      default: []
      selector:
        action: {}
    button_3_hold:
      name: Button 3 Hold
      default: []
      selector:
        action: {}
    button_3_rotate_clockwise:
      name: Button 3 Rotate Clockwise
      default: []
      selector:
        action: {}
    button_3_rotate_counter_clockwise:
      name: Button 3 Rotate Counter-Clockwise
      default: []
      selector:
        action: {}
    button_4_single_press:
      name: Button 4 Single Press
      default: []
      selector:
        action: {}
    button_4_double_press:
      name: Button 4 Double Press
      default: []
      selector:
        action: {}
    button_4_hold:
      name: Button 4 Hold
      default: []
      selector:
        action: {}
    button_4_rotate_clockwise:
      name: Button 4 Rotate Clockwise
      default: []
      selector:
        action: {}
    button_4_rotate_counter_clockwise:
      name: Button 4 Rotate Counter-Clockwise
      default: []
      selector:
        action: {}
mode: parallel
max: 10
max_exceeded: silent
- platform: event
  event_type: deconz_event
  event_data:
    device_id: !input device
- platform: event
  event_type: deconz_relative_rotary_event
  event_data:
- variables:
    input_text_var: !input last_pressed
    counter_var: !input tap_counter
- choose:
    - conditions:
        - condition: template
          value_template: "{% set s = trigger.event.data.event | string %} {{ s[-1] == '0' }}"
      sequence:
        - if:
              value_template: "{% set s = trigger.event.data.event | string %} {{ s[0] != states(input_text_var) }}"
          then:
            - service: counter.reset
                entity_id: "{{ counter_var }}"
        - service: input_text.set_value
            value: "{% set s = trigger.event.data.event | string %} {{ s[0] }}"
            entity_id: "{{ input_text_var }}"
        - service: counter.increment
        - delay:
            seconds: 1
    - conditions:
          value_template: "{% set s = trigger.event.data.event | string %} {{ s[-1] == '2' }}"
          value_template: "{{ states(counter_var) > '1' }}"
      sequence:
        - choose:
            - conditions:
                  value_template: "{{ trigger.event.data.event | int(0) == 1002 }}"
              sequence: !input button_1_double_press
            - conditions:
                  value_template: "{{ trigger.event.data.event | int(0) == 2002 }}"
              sequence: !input button_2_double_press
            - conditions:
                  value_template: "{{ trigger.event.data.event | int(0) == 3002 }}"
              sequence: !input button_3_double_press
            - conditions:
                  value_template: "{{ trigger.event.data.event | int(0) == 4002 }}"
              sequence: !input button_4_double_press
  default:
    - if:
      then:
        - delay:
            milliseconds: 250
        - if:
          then:
            - stop: Double tap detected
    - choose:
        - conditions:
            - condition: trigger
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '1' and trigger.event.data.rotation > 0 }}"
          sequence: !input button_1_rotate_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '1' and trigger.event.data.rotation < 0 }}"
          sequence: !input button_1_rotate_counter_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '2' and trigger.event.data.rotation > 0 }}"
          sequence: !input button_2_rotate_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '2' and trigger.event.data.rotation < 0 }}"
          sequence: !input button_2_rotate_counter_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '3' and trigger.event.data.rotation > 0 }}"
          sequence: !input button_3_rotate_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '3' and trigger.event.data.rotation < 0 }}"
          sequence: !input button_3_rotate_counter_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '4' and trigger.event.data.rotation > 0 }}"
          sequence: !input button_4_rotate_clockwise
        - conditions:
              id:
                - rotation
              value_template: "{{ states(input_text_var) == '4' and trigger.event.data.rotation < 0 }}"
          sequence: !input button_4_rotate_counter_clockwise
        - conditions:
              value_template: "{{ trigger.event.data.event == 1002 }}"
          sequence: !input button_1_single_press
        - conditions:
              value_template: "{{ trigger.event.data.event == 1001 }}"
          sequence: !input button_1_hold
        - conditions:
              value_template: "{{ trigger.event.data.event == 2002 }}"
          sequence: !input button_2_single_press
        - conditions:
              value_template: "{{ trigger.event.data.event == 2001 }}"
          sequence: !input button_2_hold
        - conditions:
              value_template: "{{ trigger.event.data.event == 3002 }}"
          sequence: !input button_3_single_press
        - conditions:
              value_template: "{{ trigger.event.data.event == 3001 }}"
          sequence: !input button_3_hold
        - conditions:
              value_template: "{{ trigger.event.data.event == 4002 }}"
          sequence: !input button_4_single_press
        - conditions:
              value_template: "{{ trigger.event.data.event == 4001 }}"
          sequence: !input button_4_hold
Hi, thanks for the blueprint! I’m currently struggeling to dim my hue lights with the rotation of the dial. I’m using the “Switch light on” function with changing the brightness in steps of 20.
Unfortunaltely it seems that a fast rotation is spamming a lot of events which are causing a huge delay. Everything gets quite unresponsive when turning the dial.
Do you have any idea how to smoothen the dimming experience and keeping it still responsive?
I have a tap and dial switches on each side of the bed and they work well with this Blueprint. The only trouble is, I’m now trying to add a hue button to kill all the lights when I leave the room, and when I add it via deconz, the tap and dial buttons stop working. I had something similar when I initially added to second Tap and Dial but that was easily solved by creating a unique Last Pressed Input Text Helper for it. Unfortunately, I can’t do this for the button as it’s not recognised by this blueprint.
Is there any way around this?
