Zigbee configuration in deconz doesn’t seem to do much. But I did end up with two Phoscon integrations. With different number of devices and entities.
There are two lines with exactly the same info, just different Id’s.
In the login page for Phoscon I have two instances of Phoscon-GW. One is greyed out.
I guess this is what happens when I do something I don’t know about and should not do…
I do get some errors in the system log:
20-05-08 13:52:51 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-05-08 13:52:51 INFO (MainThread) [supervisor.addons] Phase 'application' start 0 add-ons
20-05-08 13:52:51 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-05-08 13:52:51 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardware monitor
20-05-08 13:52:51 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-05-08 13:52:51 INFO (MainThread) [supervisor.host.info] Update local host information
20-05-08 13:52:51 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-05-08 13:52:51 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-05-08 13:52:51 INFO (MainThread) [supervisor.host.services] Update service information
20-05-08 13:52:51 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-05-08 13:52:52 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-05-08 13:52:52 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-05-08 13:52:52 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-05-08 13:53:04 WARNING (MainThread) [supervisor.api.ingress] Ingress for G_FJm4a_DqNXhpjTfSITAhPt6Ry6xTctGitdawvVlj4 not available
20-05-08 13:53:08 WARNING (MainThread) [supervisor.api.ingress] Ingress for G_FJm4a_DqNXhpjTfSITAhPt6Ry6xTctGitdawvVlj4 not available
20-05-08 13:53:10 WARNING (MainThread) [supervisor.api.ingress] Ingress for G_FJm4a_DqNXhpjTfSITAhPt6Ry6xTctGitdawvVlj4 not available
20-05-08 13:53:33 ERROR (MainThread) [supervisor.api.ingress] Ingress error: None
20-05-08 13:54:32 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 13:54:42 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 13:54:52 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 13:55:02 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 13:55:12 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 13:55:35 INFO (SyncWorker_13) [supervisor.docker.interface] Stop addon_core_deconz application
20-05-08 13:55:36 INFO (SyncWorker_13) [supervisor.docker.interface] Clean addon_core_deconz application
20-05-08 13:55:38 INFO (SyncWorker_7) [supervisor.docker.addon] Start Docker add-on homeassistant/armhf-addon-deconz with version 5.3.2
20-05-08 13:55:50 INFO (MainThread) [supervisor.discovery] Send discovery to Home Assistant deconz from core_deconz
20-05-08 13:55:50 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-05-08 13:55:50 INFO (MainThread) [supervisor.discovery] Discovery a2255922bad94dc0b28b07f231c64a4f message send
20-05-08 13:55:54 ERROR (MainThread) [supervisor.api.ingress] Ingress error: None
20-05-08 14:01:42 ERROR (MainThread) [supervisor.api.ingress] Ingress error: None
20-05-08 14:04:35 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:04:45 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:04:55 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:05:05 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:05:15 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:05:25 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:05:34 ERROR (MainThread) [supervisor.api.ingress] Ingress error: None
20-05-08 14:05:35 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:05:45 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:05:54 ERROR (MainThread) [supervisor.api.ingress] Ingress error: None
20-05-08 14:05:55 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:06:05 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
20-05-08 14:06:06 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 502, message='Invalid response status', url='http://172.30.33.0:8099/websocket
