deCONZ problem adding IKEA bulb 1000 lm
Hi!
Does anyone else have a problem with adding a Trådfri light bulb 1000lm together with conbee and deconz?
I have successfully managed to add other trådfri bulbs and switches.
Is this a know bug or is it something with my setup?
I have the latest version and firmware:
2.05.39
26240500
Any suggestions?
I have two E27 1000 lumen bulbs. The one was added without fuss, but the second one did require a couple of tries before it was added. I have however the problem that both my bulbs turn themselves one and off some times…
What I’ve heard is that you should have the search for a light active and then reset the hue light to get it to pair
Thank you, i have tried it all, i even went to change the bulb in the store.
All other lights works perfectly it is just this one that is causing trouble.
