Basically I want to use one raspberry pi with Hassio and RaspBee to control Xiaomi Sensors so I don’t have to use the Xiaomi Gateway or another raspberry pi strictly for the RaspBee.
Has anyone accomplished this? Maybe it would work if I manually installed home assistant instead of using hassio.img?
I have installed Hassbian on my RPi3 and installed Hassio on top by using the install script.
Just change the Hassbian port or deactivate the Hassbian service to avoid conflicts.
After that you can install Deconz as it is suggested on their github page…
IMHO the best of both worlds now. I have one Hass instance with full system access and the other with Docker containers and Hassio addons.
