I updated the deconz add on to the latest version 5.3.6 and following I updated the ConbeeII device firmware to the the version of 22-5-2020 0x26580700 .
HA worked well before the deconz updating. After the deconz updating, all the HA system seems to run slowly and in particular the interactions with devices associated to the conbeeII…Every 15 sec or after the HMI interaction with some deconz device (i.e. light,sensors…) the deconz device icons presented in the lovelace page went in disabled mode(light grey)… After 30 sec… they reappeared in normal mode.
Following the log extract of the deconz addon
06:24:20:582 GW firmware version: 0x26580700
06:24:20:582 GW firmware version is up to date: 0x26580700
06:24:20:585 ZCL attribute report 0x7CB03EAA00ADF2DB for cluster: 0x0008, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:24:21:792 New websocket 172.30.32.1:57944 (state: 3)
06:24:23:253 ZCL attribute report 0x7CB03EAA00B08155 for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:24:32:674 don't close database yet, keep open for 900 seconds
06:24:32:695 Current channel 15
06:24:32:702 Device TTL 3713 s flags: 0x7
06:24:37:270 ZCL attribute report 0x7CB03EAA00ABADBF for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:24:42:204 don't close database yet, keep open for 900 seconds
06:24:42:212 ZCL attribute report 0x7CB03EAA00ABADBF for cluster: 0x0008, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:24:46:974 don't close database yet, keep open for 900 seconds
06:26:27:018 don't close database yet, keep open for 900 seconds
06:26:27:019 Remove websocket 172.30.32.1:57944 after error Unknown error
06:26:27:021 New websocket 172.30.32.1:58178 (state: 3)
06:26:27:045 Current channel 15
06:26:27:053 Device TTL 3598 s flags: 0x7
06:26:27:061 ZCL attribute report 0x7CB03EAA00ABADBF for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:26:27:065 ZCL attribute report 0x7CB03EAA00ADF2DB for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:26:27:069 ZCL attribute report 0x7CB03EAA00ADF2DB for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:26:47:272 don't close database yet, keep open for 900 seconds
06:26:47:276 ZCL attribute report 0x7CB03EAA00ADF2DB for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:27:13:581 don't close database yet, keep open for 900 seconds
06:27:13:581 Remove websocket 172.30.32.1:58178 after error Unknown error
06:27:13:586 ZCL attribute report 0x7CB03EAA00ADF2DB for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
06:27:27:887 don't close database yet, keep open for 900 seconds
06:27:27:888 New websocket 172.30.32.1:58586 (state: 3)
06:27:27:906 Current channel 15
06:27:27:914 Device TTL 3538 s flags: 0x7
06:27:27:922 no button map for: lumi.weather ep: 0x01 cl: 0x0402 cmd: 0x0A pl[0]: 000
06:27:27:922 ZCL attribute report 0x00158D00034CECC6 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
06:27:27:926 no button map for: lumi.weather ep: 0x01 cl: 0x0405 cmd: 0x0A pl[0]: 000
06:27:27:926 ZCL attribute report 0x00158D00034CECC6 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
06:27:27:930 no button map for: lumi.weather ep: 0x01 cl: 0x0403 cmd: 0x0A pl[0]: 000
06:27:27:930 ZCL attribute report 0x00158D00034CECC6 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
06:28:44:529 don't close database yet, keep open for 900 seconds
06:28:44:530 Remove websocket 172.30.32.1:58586 after error Unknown error
