I do not think it is just a browser issue.
I do get a bit different results using different browsers, but there might be something deeper in HA’s /raspberrys way to handle addresses it gives to devices and/ or with sll.
I cannot track down the issue in specific, but few things I have tried/ noticed:
Some time again there was change in deconz addon, I do not recall which version, but then in the Configuration there were as a new feature (in my case) 2 addresses to be chosen for deconz device (in my case ConbeeII), which was not the case earlier. Earlier i think they had to be set manually(?)
These addresses were:
/dev/ttyAMA0
and
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2252230-if00
However, before the change the address the stick used, was
/dev/ttyACM0
Well today, after updating the core from 2022.9.4 to 2022.9.5 there seemed to be some kind of conflict with devices addresses. Mys ESPHome showed 502 Bad gatewy and just as posted here, deconz VNC was not working, even though I could get to the Phoscon App. Not with all the browesers I haver, though
I sorted the ESPHome issue by turning off the SSL, since quite often it seems to be the case that after updates ssl seems to be a bit lost at some time
What comes to deconz, I edited the configuration in yaml mode and changed the device address to the original
/dev/ttyACM0
…and it started to work again with no issues. Even though this address is not even listed in the hardware section of HA and not offered by deconz configuration
After that I turned ssl back on in ESPHome and it worked again, too.
After this i changed deconz address back to
…and it works again.
Something with either ssl or internal device addresses??? Something requiring time before things start to operate again?
I recall, however cannot be sure, that I had something similar earlier as well, and it just took some time to settle, and the problem suddenly went away?
