Just moved over to Deconz from Xiaomi binding… thank you for those who offered advice…
BIG ISSUE: My Xiaomi devices do not update. I obviously need instance updates on motion, door etc and they dont update at all other than when they are added.
Information that may help:
Adding devices is all fine, they add first time, and all show up in the Photocon App thing (although also dont update themselves there either).
I have the following error in my log which I know is to do with Deconz, but I dont have an option to generate an authentication key as per addon instructions.
19-10-19 18:22:32 WARNING (MainThread) [hassio.api.security] No API token provided for /api/config
I have the following additional errors which I think are relevant.
19:25:42:463 APS-DATA.indication from unknown node 0x00158D000123262E
19:25:42:464 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:25:42:464 ZCL attribute report 0x00158D000123262E for cluster 0x0406, ep 0x01
19:25:47:857 APS-DATA.indication from unknown node 0x00158D000123262E
19:25:47:857 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:25:47:857 ZCL attribute report 0x00158D000123262E for cluster 0x0406, ep 0x01
19:25:48:359 Websocket disconnected 192.168.69.110:50709 (state: 0)
19:25:49:642 New websocket 192.168.69.110:50741 (state: 3)
19:25:52:015 APS-DATA.indication from unknown node 0x00158D00015E672E
19:25:52:015 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:25:52:016 ZCL attribute report 0x00158D00015E672E for cluster 0x0406, ep 0x01
19:25:52:483 Websocket disconnected 192.168.69.110:50741 (state: 0)
19:25:53:245 APS-DATA.indication from unknown node 0x00158D000123262E
19:25:53:245 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:25:53:245 ZCL attribute report 0x00158D000123262E for cluster 0x0406, ep 0x01
19:25:53:789 New websocket 192.168.69.110:50744 (state: 3)
19:25:57:683 APS-DATA.indication from unknown node 0x00158D00015E672E
19:25:57:683 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:25:57:683 ZCL attribute report 0x00158D00015E672E for cluster 0x0406, ep 0x01
19:26:03:703 APS-DATA.indication from unknown node 0x00158D00015E672E
19:26:03:703 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:26:03:703 ZCL attribute report 0x00158D00015E672E for cluster 0x0406, ep 0x01
19:26:09:345 APS-DATA.indication from unknown node 0x00158D000123262E
19:26:09:345 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:26:09:345 ZCL attribute report 0x00158D000123262E for cluster 0x0406, ep 0x01
19:26:11:796 Websocket disconnected 192.168.69.110:50744 (state: 0)
19:26:13:562 Invalid admin password hash: $1$8282jdkm$w.o6XjJEGLzAYkVqLPAYx1
19:26:16:828 Current channel 20
19:26:16:836 Device TTL 3328 s flags: 0x7
19:26:17:572 created username: 0EE605061F, devicetype: Phoscon#B1536x754
19:26:18:935 New websocket 192.168.69.110:50779 (state: 3)
19:26:21:066 Websocket disconnected 192.168.69.110:50779 (state: 0)
19:26:22:257 New websocket 192.168.69.110:50781 (state: 3)
19:26:22:832 don't close database yet, keep open for 900 seconds
19:26:22:871 dev /dev/ttyAMA0
19:26:22:871 GW firmware version: 0x264a0700
19:26:22:871 GW firmware version is up to date: 0x264a0700
19:27:16:819 Current channel 20
19:27:16:821 Device TTL 3268 s flags: 0x7
19:28:16:827 Current channel 20
19:28:16:835 Device TTL 3208 s flags: 0x7
19:28:55:473 APS-DATA.indication from unknown node 0x00158D00015E672E
19:28:55:473 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:28:55:473 ZCL attribute report 0x00158D00015E672E for cluster 0x0406, ep 0x01
19:29:01:329 APS-DATA.indication from unknown node 0x00158D00015E672E
19:29:01:329 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:29:01:329 ZCL attribute report 0x00158D00015E672E for cluster 0x0406, ep 0x01
19:29:02:015 APS-DATA.indication from unknown node 0x00158D000123262E
19:29:02:015 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
19:29:02:015 ZCL attribute report 0x00158D000123262E for cluster 0x0406, ep 0x01
19:29:06:486 APS-DATA.indication from unknown node 0x00158D00015E672E
19:29:06:487 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
Any help really appreciated as I dont want to go back to Xiaomi binding if possible.
