deConz Zigbee Plugsocket not updating frequently
Problem:
I have some BlitzWolf plug sockets with power meter. After I update to the new HomeAsisstant Core version they don’t update every few seconds, now they update every few minutes. This is really critical, because I have a few automations (if power consumption is above a threshhold, turn of my leds and turn on the lights) however now it takes up to 7 minutes some times to run the automation.
Question:
Is there a solution to make them refresh more frequently? Maybe with tinkering with the config file.
Thanks in advance.
Shouldn’t be any change to update frequency in the integration . Did you also update deconz?
Yes I think deConz had an update as well that I downloaded.
You should start by downgrading deconz then I think
Alright, I will try that, when I‘m home and keep you up to date.
Thank you so much it worked. This somehow didn’t come to my mind.
