Hi everyone,
After spending a number of years using Samsung SmartThings (ST) extensively, I’ve finally decided to adopt Home Assistant (HA) to work around the limitations on ST.
Now I know that this topic has come up a number of times, but after extensive searching both here and generally online I’m still unable to get a clearly defined answered and ideally a solution.
At the most basic, simple level…:
I have an Aqara H1 wall switch. Single rocker, no neutral.
I’m using a WiFi based smart bulb to the circuit controlled by the H1 wall switch. I wish to use automation to perform actions on the bulb, rather than using the switch to physically disconnect / connect the power to the light bulb socket. I believe this is called “decoupled” mode within the HA community. Within the ST community it was called “wireless mode”. I want to point out that the community made driver for the Aqara switches fully supported this “wireless mode” / “decoupled mode” operation in ST.
My ultimate goal is for the light bulb socket to be powered on at all times, and any action regarding the light bulb itself (e.g. on, off) is all performed based on actions defined in HA and trigged by a press / double press of the button on the Aqara H1 wall socket.
Currently I’m using Home Assistant Green with the SkyConnect dongle, although I’m looking at moving some of these over to using HomeKit instead (I don’t own anything Apple, I mean HomeKit solely on HA).
Can someone, anyone give any solid news on this? I’ve heard so many different “solutions”, some of which are years old, some of which apparently work for some but not for others. Other people say it’s impossible. Others mention a requirement to use zigbee2mqtt over ZHA. I’ve heard that the best support is provided by using he Xiaomi Gateway (Aqara) integration, but this literally states that “decoupled mode” doesn’t work and isn’t supported. (See here under “Unsupported devices”): Xiaomi Gateway (Aqara) - Home Assistant (home-assistant.io)
Given that the hardware is capable of doing what people are asking, and we have THE open home automation platform on the planet, can we get a solid answer as to how we can make this work?
I’m purposefully creating this as a new topic due to out of date existing posts and improvements to firmware, HA and the general march of time.
Thanks in advance for your time reading and hopefully for your help
Side note: Being fairly new to the HA scene (but fairly advanced with home automation in general through my SmartThings use) I’m comfortable with using Lovelace, and happy to configure YAML but I’m not familiar with the pairing of YAML and HA. I’m currently making the transition from ST to HA and this will take me some time to do, so I’m happy to act as a guinea pig / alpha/beta tester in this.
