UgoCo
January 12, 2023, 9:01am
1
Hi, I’m looking for help configuring my ecovacs 920 deebot by following this guide:
https://deebot.readthedocs.io/integrations/home-assistant/examples/ui/advanced/
I installed:
Vacuum-card
Button card
Deebot 4 Home Assistant
now I need someone to guide me in placing the code inside the configuration files, thank you in advance, hoping someone will come forward
UgoCo
January 12, 2023, 11:40am
2
first of all i replaced the deebot name, then i put the scripts in the scripts.yaml file
script:
deebot_clean:
description: Start a deebot cleaning task
variables:
queue: input_text.deebot_susi_queue
vacuum_bot: vacuum.susi
sequence:
- alias: Get room numbers
variables:
# See for appending to list
# https://github.com/home-assistant/core/issues/33678#issuecomment-609424851
rooms: >-
{%- set queue_split = states(queue).split(",") -%}
{%- set rooms = state_attr(vacuum_bot, "rooms")-%}
{%- set data = namespace(rooms=[]) -%}
{%- for room_name in queue_split -%}
{%- set data.rooms = data.rooms + [rooms[room_name]] -%}
{%- endfor -%}
{{ data.rooms | join(",") }}
- alias: Send cleaning job to vacuum
service: vacuum.send_command
entity_id: "{{ vacuum_bot }}"
command: spot_area
params:
rooms: "{{ rooms }}"
cleanings: 1
deebot_room_queue:
description: Add/Remove a room from the queue
fields:
queue:
description: The queue variable
example: input_text.deebot_susi_queue
room:
description: Room, which should be removed or added
example: kitchen
sequence:
- service: input_text.set_value
entity_id: "{{ queue }}"
value: >-
{%- set queue_state = states(queue) -%}
{%- set queue_split = queue_state.split(",") -%}
{%- if queue_state | length == 0 -%}
{{ room }}
{%- elif room in queue_split -%}
{{ queue_split | reject("eq", room) | list | join(",")}}
{%- else -%}
{{ (queue_split + [room]) | join(",") }}
{%- endif -%}
this code in automations.yaml
automation:
- alias: Staubsauger Zimmer resetieren
- platform: event
event_type: deebot_cleaning_job
event_data:
status: finished
condition: []
- alias: Reset room queue
entity_id: input_text.deebot_susi_queue
value: ""
mode: single
and this in configuration.yaml
recorder:
exclude:
entities:
- input_text.deebot_susi_queue
- script.deebot_room_queue
entity_globs:
- sensor.deebot_*_queue_*
input_text:
deebot_susi_queue:
name: Susi Raum Reihenfolge
max: 255 # Current max limit. See https://www.home-assistant.io/integrations/input_text/#max
# Room name comes from the integration to match attribute names
template:
unique_id: deebot_susi_queue
- platform: state
# Add for each room the following. Change room_name accordingly
- unique_id: deebot_susi_queue_living_room
# room_name must match the room name provided by the vacuum
state: >
{% set room_name = "living_room" %}
{% set queue = trigger.to_state.state.split(",") %}
{{ queue.index(room_name)+1 if room_name in queue else 0 }}
UgoCo
January 12, 2023, 11:43am
3
later i put this code in config/lovelace/button_card_templates.yaml
button_card_templates:
vacuum_service:
color: var(--text-color)
entity: vacuum.susi # change me
tap_action:
action: call-service
service_data:
entity_id: vacuum.susi # change me
lock:
enabled: |
[[[ return variables.enabled ]]]
exemptions: []
styles:
card:
- height: 80px
lock:
- color: var(--primary-text-color)
state:
- operator: template
value: |
styles:
card:
- color: var(--disabled-text-color)
vacuum_room:
variables:
# change me
lock_enabled: >
[[[ return ['cleaning', 'paused'].includes(states['vacuum.susi'].state)
state:
value: |
[[[ return variables.lock_enabled && entity.state == 0 ]]]
styles:
card:
- styles:
card:
- background-color: var(--primary-color)
operator: ">="
value: 1
styles:
card:
- font-size: 12px
grid:
- position: relative
custom_fields:
order:
- display: |
if (entity.state == "0")
return "none";
return "block";
- position: absolute
- left: 5%
- top: 5%
- height: 20px
- width: 20px
- font-size: 20px
- font-weight: bold
- line-height: 20px
custom_fields:
order: |
[[[ return entity.state ]]]
tap_action:
service: script.deebot_room_queue
service_data:
lock:
enabled: |
[[[ return variables.lock_enabled ]]]
exemptions: []
UgoCo
January 12, 2023, 11:45am
4
and finally in the dashboards card:
type: vertical-stack
cards:
- type: custom:vacuum-card
stats:
default:
- entity_id: sensor.susi_life_span_brush # change me
unit: "%"
subtitle: Hauptbürste
- entity_id: sensor.susi_life_span_side_brush # change me
unit: "%"
subtitle: Seitenbürsten
- entity_id: sensor.susi_life_span_filter # change me
unit: "%"
subtitle: Filter
cleaning:
- entity_id: sensor.susi_stats_area # change me
unit: m²
subtitle: Geputzte Fläche
- entity_id: sensor.susi_stats_time # change me
unit: Minuten
subtitle: Reinigungsdauer
show_status: true
show_toolbar: false
compact_view: true
- type: custom:button-card
color: auto-no-temperature
name: Räume zum Putzen auswählen
styles:
card:
- font-size: 18px
- height: 30px
name:
- color: var(--primary-color)
- type: horizontal-stack
cards:
# Add the following chard for each room. Change values accordingly
template: vacuum_room
entity: sensor.deebot_susi_queue_living_room # change me
icon: mdi:sofa
tap_action:
service_data:
room: living_room # change me
cards:
- type: conditional
conditions:
- entity: vacuum.susi # change me
state_not: cleaning
state_not: paused
card:
template: vacuum_service
icon: mdi:play
tap_action:
service: script.deebot_clean
variables:
# change me
enabled: |
return ((!states['input_text.deebot_susi_queue'].state ||
states['input_text.deebot_susi_queue'].state.length === 0)
&& ['docked', 'idle', 'error', 'returning'].includes(entity.state))
- type: conditional
conditions:
state: cleaning
card:
color: auto
icon: mdi:pause
tap_action:
service: vacuum.pause
service_data:
styles:
card:
- height: 80px
- background-color: var(-color)
- type: conditional
conditions:
state: paused
card:
color: auto
icon: mdi:play-pause
tap_action:
service: vacuum.start
service_data:
styles:
card:
- height: 80px
icon: mdi:stop
tap_action:
service: vacuum.stop
variables:
enabled: |
return !(['cleaning', 'paused', 'returning'].includes(entity.state))
cards:
icon: mdi:home-map-marker
name: Zurück zur Ladestation
tap_action:
service: vacuum.return_to_base
variables:
enabled: |
return ['docked', 'returning'].includes(entity.state)
color: auto
icon: mdi:map-marker
tap_action:
service: vacuum.locate
service_data:
styles:
card:
- height: 80px
- type: picture-entity
entity: camera.susi_live_map # change me
tap_action:
action: none
hold_action:
action: none
show_state: false
show_name: false
UgoCo
January 12, 2023, 11:47am
5
now i should create “vacuum room” and “vacumm service” , but i don’t know how to do it
DeLorean
(Loryan Strant)
January 21, 2023, 4:12am
7
How did you get the data on the rooms into HA? Were you lucky enough to have a complete map in your Deebot?
nightrave
(Nightrave)
November 19, 2023, 3:07am
8
Did anyone got this working? Seems straight forward, but I can’t even paste this into configs as home assistant throws an error when saving the code.
