today I was using the deebot vacuum integration for my T9, I found that official phone app does show the cleaning area’s squared meters, that increases while vacuum is cleaning.
I was searching the same for Home Assistant official integration but seems it’s not available.
is it possible to implement the sensor’s refresh while vacuum is cleaning ?
If official phone app shows it, it means that’s possible to do in some way.
I need it because, when using mop, I’ve to refill water into the tank after x cleaned squared meters (and this implementation is the best way, independent from cleaning order), otherwise vacuum continues cleaning without water (and it means it is not cleaning as I wish )
Having such refreshed value can help so I can create an automation that, when cleaned area is higher than a value, it pause the vacuum and send me a notification to add water.
Thanks.
