Deebot T8 AIVI - Send bot to position x,y?
I am trying to switch from ioBroker to Home Assistant and currently I am having troubles in integration my Deebot T8 AIVI.
In ioBroker it was possible to send the bot to a defined position by executing “ecovacs-deebot.0.control.extended.goToPosition” and adding x and y coordinates.
I am searching for something similar in the integration GitHub - DeebotUniverse/Deebot-4-Home-Assistant: Home Assistant integration for deebot vacuums but I have not found something like that.
I noticed that there is such a thing like “deebot_custom_command” and it may be possible to create such a move command here but here I am lost.
Maybe it is possible to reverse engineer the move command from ioBroker and add it to the project or workaround it with the custom command.
Hope someone can help since the move command would be essential for my setup.
Thanks.
I’m looking for the same. Do you have a solution?
