Deebot vacuum.send_command
Hey Friends,
First time caller long time listener. Looking for some insight. I’ve got HA setup with Deebot4HAS working and communicating properly. Im trying to create a script to then program into a button to clean specific rooms.
Within the developer tools I can get the command to run via call service, but if i take that code and make a script with it, it says it runs but nothing happens. Obviously Im doing something wrong. Below is the call service code and then how i’ve put it into the script. Any insight would be much appreciated.
call service code (which works):
service: vacuum.send_command
  entity_id: vacuum.john_2
  command: clean_spot
  params:
    rooms: 2
    cleanings: 1
script (which does nothing)
alias: clean_kitchen
sequence:
  - service: vacuum.send_command
      command: clean_spot
      params:
        rooms: 2
        cleanings: 1
mode: single
try
command: spot_area
instead of
command: clean_spot
