Deep_sleep and config entries for an epaper
I have a seeed Studio ePaper E1001 which I use to display data, that does not change a lot. So I put it into deep_sleep as long and often as I can.
I also have a config item in the ESP.yaml
number:
    name: "min Sleep During Work"
    unit_of_measurement: "min"
    min_value: 1
    max_value: 1440     # up to 24 hours
    step: 10
    mode: box
    update_interval: never
    optimistic: true
    restore_value: true
    initial_value: 58   # default: 58 minutes
    icon: "mdi:sleep"
    entity_category: config
So that I see all configurable items for this ESP at the device itself. It “somehow” works. The problem arises, that as the ESP sleeps a lot, it is hard to change the config. During testing and googleing I think these options exist:
a.) Have a helper in HomeAssistant that duplicates this value, and if the ESP connects, use the helper to set this config value. Pro: Works without waiting for the ESP to wake up, CON: Have to do it “somewhere” else, not at the device, where I would love to have it.
b.) Live with what I have, and maybe have something like a “maintanance” wakeup, that is longer, so I can than change things easier.
I can live with both options, but do like the option better, to have the config for the ESP handled in the device area like it is here:
I am asking, if there is not somthing like: “Push config, if ESP connects”, so this would have the config there, throwing the error if the ESP is in deep sleep like it throws the error now, but maybe it coul dbe a “warning”, that it is pushed later, if ESP connects.
I use API: connect, which reliably sends the data to the ESP.
Is there a way, to use the nice configuration at the device area, or how do you solve such configs, that the ESP might get, if he connects from wakeup?
many thanks
Juergen
I’m not really sure what are you exactly after, but have a look at this thread:
