Deep Sleep duration by time of day
I’m trying to figure out how to control the deep sleep component’s duration at different times of day. For example, during the day, I want it to run for 20 minutes and then sleep for 1 hour. After 7pm, I want it to run for 20 minutes and sleep for 3 hours.
Is this possible?
It should be possible.
If you use the deep_sleep_enter action, the sleep_duration parameter is templatable.
You can, however, also use the undocumented set_sleep_duration() function
Here’s a tread about it:
