Deep sleep mqtt for espcam
hi,
i’m trying to make an espcam which is controled by a binary sensor.
I would like to use mqtt but i can’t make it work.
nothing I try is working and i m loosing my mind and my sanity…
here’s the actual code:
in esphome :
substitutions:
  devicename: espcam0
  friendly_name: espcam0
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
api:
  encryption:
    key: "BkAvA2SOBK0tnuiW2tQR/PnwfA79RYMyeGs3UZPin18="
# Enable logging
logger:
# Enable Home Assistant API
ota:
  password: "6b408b2147dd1cf8c45c82d3470229f3"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Espcamtest Fallback Hotspot"
    password: "DZrNdM4Oa8Li"
captive_portal:
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 10MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
# Image/Video settings, https://esphome.io/components/esp32_camera.html
  max_framerate: 24 fps    # default: 10 fps, max 60
  idle_framerate: 0.2 fps # default: 0.1 fps - framerate for 'picture' in HA dashboard
  resolution: 800x600
  jpeg_quality: 10
  vertical_flip: False
  horizontal_mirror: False
  contrast: 0 # default: 0, variable -2 to 2
  brightness: 0 # default: 0, variable -2 to 2
  saturation: 0 # default: 0, variable -2 to 2
# Server video/pictures, https://esphome.io/components/esp32_camera_web_server.html
esp32_camera_web_server:
  - port: 8080
    mode: stream
  - port: 8081
    mode: snapshot
  - platform: wifi_signal
    name: $friendly_name Wifi signal
    update_interval: 10s
  - platform: uptime
text_sensor:
  - platform: version
    name: $friendly_name ESPHome Version
  - platform: wifi_info
    ssid:
switch:
  - platform: restart
output:
#flashlight
  - platform: gpio
    pin: GPIO4
#statuslight led 33 for wifi connect
  - platform: gpio
    pin:
      number: GPIO33
      inverted: True
light:
#flashlight
  - platform: binary
    output: gpio_4
  - platform: binary
    output: gpio_33
    name: $friendly_name wifi light state
deep_sleep:
  run_duration: 1 min
  sleep_duration: 1 min
binary_sensor:
  - platform: homeassistant
    name: Prevent Deep Sleep0
    entity_id: input_boolean.deep_sleep_disable0
    name: control deep sleep0
    entity_id: input_boolean.deep_sleep_control0
mqtt:
  broker: !secret mqtt_broker
  username: !secret mqtt_username
  password: !secret mqtt_password
  discovery: True
  discovery_retain: True
  on_message:
    - topic: espcam0/deep_sleep/deep_sleep_control0
      payload: "on"
      then:
        - deep_sleep.prevent: deep_sleep_0
      payload: "off"
      then:
        - deep_sleep.allow: deep_sleep_0
in home assistant:
automation:
  - id: deep_sleep_control0_on
    alias: "Deep Sleep Control On"
      platform: state
      entity_id: binary_sensor.deep_sleep_control0
      to: 'on'
      - mqtt.publish:
          payload: "on"
          retain: true
  - id: deep_sleep_control0_off
    alias: "Deep Sleep Control Off"
      platform: state
      to: 'off'
      - mqtt.publish:
          payload: "off"
          retain: true
  - id: deep_sleep_prevent
    alias: "Deep Sleep Prevent"
      platform: mqtt
      payload: "on"
      - logger.log: 'deep sleep interrompu'
  - id: deep_sleep_allow
    alias: "Deep Sleep Allow"
      platform: mqtt
      payload: "off"
      - logger.log: 'deep sleep autorisé'
      - deep_sleep.enter: deep_sleep_0
  deep_sleep_control0:
    initial: off
