I just installed my first dimmer switch in my bathroom.
The idea is to have a default low brightness during the night and a normal one during the day.
I found out that it’s not possible to change the brightness without switching on and off the light.
I’d like to avoid this so I was digging and might have found an other way around this
The Fibaro Dimmer has a config parameter for this :
19: Forced switch on brightness level
If the parameter is active, switching on the Dimmer (S1 single click) will always set this brightness level. Available settings: 0 - function disabled; 1-99 - percentage level of brightness; Default setting: 0
It seems to be what I’m looking for as it’s possible with an automation to change the config parameter, but being new to z-wave I wanted to be sure that changing a config parameter often is considered a good practice
Thanks in advance
