Default bulb brightness
Hi
Yes I’m new but learning loads.
Moved all stuff over from smartthings but now want to do more complex things.
So the wife still turns the light off at the wall and when they are turned back on (before an automation kicks in) the lights are not full brightness.
Is there a way that when device comes online set brightness to 6500?
Thanks in advance
Two things…
If this causes issues in your install you have a design issue. I assume you’re using bulbs not switches…
That said look up light profiles. I think documentation on profiles are under the light integration docs.
