When rebooting the system there are no errors, but when coming from an update I always have to restart the system because default_config hasn’t been loaded. no errors in logs
Do you have default_config: in your configuration.yaml file?
Sorry for the late reply…but it’s on top of the configuration.yaml. It always loads correctly but not when coming from an update-restart
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
