Hi i have found in a few recent updates my config has caused issues as it was not the default. I was able to change it further to correct my last couple of isses such as TTS, now i think its the route cause of the new repairs dashboard not being available.
So i was thinking at many points i have messed with my Config file and now everytime there is an update i get issues, i dont know how to get it back to standard default. i would still like to have the include other files as it makes it easier to organise
what should i be doing. TIA my config is as follows
homeassistant:
customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 3
#text to speech
tts:
- platform: google_translate
#include files
group: !include groups.yaml
sensor: !include sensor.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
template: !include template.yaml
google_assistant: !include google_assistant.yaml
frontend:
themes: !include_dir_merge_named themes
#Who is home
device_tracker:
- platform: ping
hosts:
me: 192.168.0.16
her: 192.168.0.15
#history
history:
# media_source: media browser
media_source:
