No matter what I do. After the installation of homeassistant the web interface only run once. Next time if gives error configuration is invalid. If I delete the config file. It regenerates it and the web interface is up. But only its a matter of reboot. As soon as you reboot the default config file becomes invalid and web interface is gone away.
Testing configuration at /home/homeassistant/.homeassistant
17-03-21 14:27:43 INFO (MainThread) [homeassistant.setup] Setting up introduction
17-03-21 14:27:43 INFO (MainThread) [homeassistant.setup] Setting up sun
17-03-21 14:27:44 INFO (MainThread) [homeassistant.setup] Setting up sensor
17-03-21 14:27:44 INFO (MainThread) [homeassistant.setup] Setting up conversation
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.config. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py", line 141, in get_component
module = importlib.import_module(path)
File "/usr/lib/python3.4/importlib/__init__.py", line 109, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 2254, in _gcd_import
File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
File "<frozen importlib._bootstrap>", line 1129, in _exec
File "<frozen importlib._bootstrap>", line 1471, in exec_module
File "<frozen importlib._bootstrap>", line 321, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/config/__init__.py", line 11, in <module>
from homeassistant.components.frontend import register_built_in_panel
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/__init__.py", line 12, in <module>
from homeassistant.components import api, group
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/api.py", line 26, in <module>
from homeassistant.helpers.state import AsyncTrackStates
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/state.py", line 8, in <module>
from homeassistant.components.media_player import (
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/__init__.py", line 24, in <module>
from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/__init__.py", line 34, in <module>
from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py", line 6, in <module>
from aiohttp.file_sender import FileSender
ImportError: No module named 'aiohttp.file_sender'
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Unable to find component config
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Component not found.
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.logbook. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/logbook.py", line 18, in <module>
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Unable to find component logbook
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Component not found.
17-03-21 14:27:44 INFO (MainThread) [homeassistant.setup] Setting up group
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.http. Make sure all dependencies are installed
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Unable to find component http
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Component not found.
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.frontend. Make sure all dependencies are installed
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Unable to find component frontend
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Component not found.
17-03-21 14:27:44 INFO (MainThread) [homeassistant.setup] Setting up discovery
17-03-21 14:27:44 INFO (MainThread) [homeassistant.setup] Setting up updater
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.history. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/history.py", line 20, in <module>
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Unable to find component history
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Component not found.
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.tts. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/tts/__init__.py", line 24, in <module>
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.loader] Unable to find component tts
17-03-21 14:27:44 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Component not found.
Failed config
General Errors:
- Component not found: config
- Setup failed for config: Component not found.
- Component not found: logbook
- Setup failed for logbook: Component not found.
- Component not found: http
- Setup failed for http: Component not found.
- Component not found: frontend
- Setup failed for frontend: Component not found.
- Component not found: history
- Setup failed for history: Component not found.
- Component not found: tts
- Setup failed for tts: Component not found.
Successful config (partial)
